diyAudio Sponsor
Old 29th August 2003, 11:19 PM   #31
Default more snippets on snivets
I found some more info on snivets in the RCA "Electron Tube Design" book, article by M. Bondy titled "Audio Output, Vertical-Deflection, and Horizontal-Deflection Tubes for Receiving Applications" p 669-p681, specifically pp 680,681
"... A disturbance called "snivets" is particularly annoying in the horizontal circuit. Snivets are vertical black bars, lines, or patterns which show up on the right-hand side of a kinescope picture. The effect seems to be caused by an instability in the virtual-cathode region when the anode voltage of the horizontal-deflection output tube is very low (see Fig. 9). It can result in discontinuous jumps in current during the scanning cycle. These current changes are rapid enough to produce a frequency spectrum extending through the very-high-frequency (vhf) band into the ultra-high-frequency (uhf) band. When aperiodic coupling is introduced between the tube and the tuner, the snivet signals are approximately the same in all uhf channels. To avoid this condition, the tube designer must take steps to provide proper suppression at the desired current level. Suitable tube design presents a major paradox to tube engineers. The better the design, that is, the sharper the knee, the higher the plate current at the lowest knee voltage, the more the likelihood that snivets will be present. Conversely, the more rounded the knee and, thus, the less efficient the tube, the less the likelihood of snivets, but these methods usually involve additional parts or reduce output. The design methods, which have been tried with limited success, involve varying the spacing between plate and screen grid by introducing either embosses or a metal part at right angles to the plate structure as shown in Fig. 10. The purpose is to make the plate surface irregular and, in this manner, to improve the stability in the virtual-cathode region. "
This is a little puzzling, since the positive V on G3 fix for snivets squares up the knee. Maybe this fix was found later than 1962 when written or they use more positive V than optimum for square. Seems a little late in the TV game to solve this. I have seen this snivet plate on the inside of a 6KV6 plate. And lots of tubes have an emboss in the plate structure.
Fig. 9 attached. I also tried to find some info on Barkhausen oscillation but so far no luck, I know I've seen this somewhere.
Ohms Law V = I R
Old 29th August 2003, 11:21 PM   #32
Default Figure 10
fig 10 attached
Ohms Law V = I R
Old 30th August 2003, 02:46 AM   #33
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Thanks for all the scans, just want you to know this is interesting stuff!
I wonder if it isn't forming a tuned circuit, maybe half the plate is resonating or something. Then again that would be tuned, not wideband. For wideband it would have to snap, like a spark, to generate the noise. Hmm any quantum physicists?
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Old 30th August 2003, 07:04 AM   #34
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
Default Transit time
I've had a few thoughts. Line scan is achieved by passing a constant current through an inductor in the anode of the valve, so by the time the right hand side of the scrren corresponds to the largest voltage across the inductor, which is the lowest voltage across the valve, and therefore the knee region of the pentode, as quoted from RCA.
The frequency at which the snivet oscillation happens is probably a transit time effect, not traditional inductors and capacitors. Klystrons and magnetrons are tuned amplifiers where the operating frequency is set by physical dimensions, so distorting the shape of the anode prevents the electrons from all arriving at the same time. When we're in the knee region, the suppressor grid voltage is very similar to the anode voltage, which suggests that there is a change whereby the suppressor grid is not as effective as it should be at suppressing secondary emission at the anode, resulting in electrons flying backwards and forwards between anode and the virtual cathode region near the suppressor grid.
The unstable horizontal position of the visible effects on line scan probably reflects changes in mean energy of electrons in the virtual cathode region around the suppressor grid, which we would normally call noise, perhaps leading to the term "Barkhausen oscillations."
This is all speculation, but it seems to fit the facts so far. Comments/corrections?
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 30th August 2003, 11:25 AM   #35
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Default Anecdote
http://antiqueradio.org/hallit-67.htm
I queried the rec.antiques.radio+phono newsgroup, and soon learned from TV veterans that this is "Barkhausen interference," caused by unwanted oscillation from the horizontal output tube (in this case, a 6BG6GT). The name is used, according to one old manual, because the oscillations are similar to those in a Barkhausen-Kurtz ultra-high frequency oscillator. One characteristic of this interference is that it's more noticeable with weak stations than strong ones. In reading up on the topic, I learned about other, similar types of interference, with amusing names such as "snivets" and "spooks."
Old 30th August 2003, 05:00 PM   #36
Default Barkhausen-Kurz
a quick google search on Barkhausen found this:
http://www.geocities.com/neveyaakov/...arkhausen.html
scroll down a ways until the vacuum tube picture shows
its a velocity modulation effect like whats used in microwave tubes
Ohms Law V = I R
Old 30th August 2003, 05:29 PM   #37
Default Barkhauzen-Kurz oscillator
When the plate voltage drops suddenly toward zero, electrons in transit (and there are a bunch in the virtual cathode area) are attracted back to the screen grid and oscillate back and forth thru it. Sort of like a "water hammer" effect in a pipeline when a valve is suddenly closed behind a mass of moving water, pulling a momentary vacuum behind it. Pulling up the suppressor or G3 voltage probably reduces the depth of the virtual cathode so fewer electrons are available to make trouble.
Ohms Law V = I R
Old 30th August 2003, 06:19 PM   #38
Default spooks in the electronics
This is from the RCA book again, page741:
"Spook interference is another peculiar effect associated with the horizontal-deflection circuit. This type of interference acquired its name because of its seemly mysterious nature and because its cause eluded explanation for so long. The interference appears as a vertical line or band at the extreme left edge of the raster or, in many cases, may not be visible at all because of overscan of the raster or because it is in the blanked region. Sometimes, spook interference is picked up from a neighboring receiver and may move mysteriously back and forth across the screen: service technicians have referred to this behaviour as "windshield wiper" effect.
Spook interference is generated by the damper tube. The plate current of this tube rises from zero to several hundred milliamperes in a very short time - about 0.1 microsecond. This rapidly increaseing current produces many higher - order harmonics of the horizontal scanning frequency which lie within the television frequency bands. These harmonics often get into the sync circuits and cause picture instability.
It is impossible to eliminate the harmonics produced by the rise of current in the damper tube. However, if chokes are placed in the damper leads at the tube socket, the interference is limited to that radiated by the tube itself. It may also be necessary to put a shield around the damper tube to eliminate radiation from the tube structure."
Ohms Law V = I R
Old 30th August 2003, 11:43 PM   #39
dhaen's Avatar
Looks like I remembered it on the wrong side of the picture.
Heck, that's what 35 years can do.....
Old 1st September 2003, 11:32 PM   #40
Default the last snivet - I hope!
Spangenberg's book "Vacuum Tubes" gives a discussion on pages 260 - 265 of the hysteresis around the knee in plate curves for beam power tubes. The electron distribution changes from one with virtual cathode to one with no virtual cathode in an unstable manner when plate voltage decreases thru the knee. This sudden redistribution of charge most likely triggers the Barkhauzen-Kurz oscillation causing the VHF/UHF frequencies. Figures 10.14 and 10.15 attached.
Ohms Law V = I R
FS tube tuner, Active filter kit, tube amp, amp3 Josephjcole Swap Meet 9 20th July 2007 05:05 PM
SS or tube voltage amplifying stages in an amp with tube output? ray_moth Tubes / Valves 14 4th July 2007 04:09 AM
need diy tube preamp (line-stage) recommendation and general tube advice Musiclover4 Tubes / Valves 15 24th November 2005 02:19 AM
Transformers (doughnuts in disguise?) mcai7et2 Parts 8 26th January 2003 03:26 PM
Page generated in 0.14972 seconds (85.10% PHP - 14.90% MySQL) with 11 queries
