| diyAudio Sponsor | ||
Hi all,
I'm mucking around with a microconroller controlled power supply for valve devices that adjusts voltages on various rails depending on the requirements of the valves. I was wondering if anyone could provide me with some data for heater requirements for the valves which are still frequently used and traded in HiFi/guitar amps/valve radio etc. My background's in guitar amps, so nothing there uses more than 1.5A and/or 12.6V, hense why I'm asking here. Since I'm just trying to spec the upper limits for voltage and current, and the power rating of the transformer, all I really need is the voltage and current ratings for valves which either have a high voltage or a high current. If you know of a valve which is still traded and used today and uses very high current OR high voltage, please can you post either, the voltage AND current rating for it, or its name (so I can google for a datasheet to get these specs) Rectifier valves are exempt from this; it's primarily for triodes, tetrodes and pentodes. |
#2 |
In the US there are 150mA valves for AC/DC radios (e.g. 35L6?). In Europe there are 100mA valves (U series e.g. UL84, UY85). In both cases these would have high heater voltages, up to 50V or more.
#3 |
6c33c
keep in mind that there is also a sharp inrush current unless you are using current limiting of some kind, for any valve. My amp settles at 4 amps of heater current or so. but inrush due to cold filaments requires up to 12 amps for a few moments |
| Heater to Cathode max voltage specs, including signal swings? | flysig | Tubes / Valves | 2 | 28th June 2009 09:22 PM |
| Request: Peerless driver specs | Mos Fetish | Multi-Way | 12 | 3rd February 2009 12:43 AM |
| Request specs on Noble 204Y potentiometer | glennb | Parts | 1 | 28th April 2008 04:59 PM |
| Request some Specs | ElectroPower | Subwoofers | 1 | 11th October 2005 01:28 PM |
| heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? | jarthel | Tubes / Valves | 10 | 21st July 2003 01:30 PM |
| Page generated in 0.07448 seconds (68.05% PHP - 31.95% MySQL) with 10 queries |
