Admittedly, I'm using the term HiFi loosely here.
I purchased an Epiphone Valve Junior guitar amplifier with the intent to convert it to a cheap, general use, EL84 SE monoblock audio amplifier. I found a schematic called the RH 84 SE (thanks RH Design) and used it to modify the Valve Jr. The result works and sounds much better than it ever has for HiFi use. It uses line-level inputs nicely and seems to have plenty of gain. All good so far. This is not my first amp project BUT I'm still very green with tube technology and I lack experience with these types of amplifiers. If you are interested, I invite you to stop by my blog and read up on the project. I have pictures and schematics that I simply could not list here. Here is the final schematic with my edits. If you see anything that is wrong or could be better (besides the cheap Hammond output transformer - I know) please let me know. I'm counting on more experienced amp techs to help guide me to getting this amp to sound nice(er) and not overdrive the tubes for long service life. The output transformer will be replaced at some point in the future. ![]() Thank you very much for reading! It is appreciated. |
#2 |
Interesting project!
I've built a few RH84s- it's a good simple design. Also fixed a few VJs which I bought broken. Your schematic is a bit different than the RH84, as you know. Some of the differences may be typos (?). Questions: Are you using the 12AX7 preamp tube? Is R3 really 1 meg ohm? C1 is .022 uF? You don't seem to have the Rfb 100k, which I understand is a pretty important part of the RH design Did your VJr come with a Hammond OT? I thought most of the VJs came with 'no name' Chinese iron. I wonder how the PT would do if you tried to get another 40 mA out of it for a second EL84? (stereo) |
#3 |
Has no resemblance to RH84, what did you copy off that design, really?
#4 | ||||
R3 is NOT 1M! I didn't catch that on the original schematic and thanks for pointing that out. R3 is 100K. C1 is correct at .022uF. Quote:
Don't know how the PT would handle it but for my application, mono is preferred! |
#5 |
#6 | |
Well there were a few things copied from RH84 (Rk for EL84), but most of the important features were not imitated. Wrong preamp tube & preamp wiring. No feedback Wrong coupling cap etc.... I think the OP is using the VJ PCB. It really would be simpler to just build something on a new chassis, and the PT and PSU in the VJ is not worth tearing up a guitar amp, IMO. A couple of tube sockets, a handful of caps/resistors and a new PT and you could start a proper RH84 build. But everyone has their own ideas for a project.... |
#7 |
You are both right, I failed to add some background information that explains how I got to here. I also have an updated and accurate schematic that will explain more.
Check out the post: EL84 SE advice'n'schematics needed And the updated schematic: ![]() Thank you again! |
#8 |
please excuse me, i have a small question- if i was to make my own circuit similar to that of the VJ, would it be possible to use i without an output transformer with say a 600 om resistor in series with an 8 ohm speaker grounded at the other end? im building a small guitar amp (about 3 to 8 watts) out of bis i have, using an el84- thanks in advance
#9 | |
| Epiphone Galaxy 25 transformer problem | Monty123 | Tubes / Valves | 0 | 26th January 2009 09:50 PM |
| Worlds smallest HiFi valve amp | fergs1 | Tubes / Valves | 51 | 17th September 2008 11:32 AM |
| epiphone pacemaker 50 t | uliami | Tubes / Valves | 1 | 14th July 2008 03:56 AM |
| Epiphone Galaxie 25 schematic | TRguy | Instruments and Amps | 1 | 8th January 2008 04:41 PM |
