diyAudio Sponsor
Old 15th August 2011, 08:01 PM   #1
Default Peavey valveking 112 lead (distortion) channel doesn't work
I've got a valveking 112 and a lead channel stopped working.(clean channel is working fine on 100%). I've replaced all the tubes but the problem still persist.I've searched for cold joint, got the suspicious ones resoldered but it didn't helped . Can anybody help me out with this, please?
Old 16th August 2011, 12:04 AM   #2
Enzo is offline Enzo  United States
I responded to this over in either SS Guitar or the PV forum. Check voltages around V2, and then trace signal trough the V2 circuits.
Peavey Valveking 100- static sound during warm-up Rotus623 Tubes / Valves 80 6th December 2010 03:16 PM
Peavey Valveking 112 Combo SCHEMATIC vangelis Instruments and Amps 7 13th July 2010 03:09 PM
Peavey Valve King 112 jeppix Tubes / Valves 4 8th February 2010 03:19 AM
Peavey 8.5C DeAd cHaNnEl Pbassred Solid State 3 9th May 2005 11:44 PM
channel distortion sriegel Pass Labs 15 13th February 2002 06:23 PM
Page generated in 0.06475 seconds (68.58% PHP - 31.42% MySQL) with 10 queries
