Account Disabled
Excuse this newbie question, but:
Any thoughts about the sonic effects of having both SE and push-pull in the signal path? For example, my DAC's output stage is SE, and it feeds push-pull headphone tube amp. What about the reverse, first push-pull then SE? |
#2 | ||
#3 | |
Account Disabled
#4 | |
A well balanced system pre to power amp will give a large rejection of spurious signal such as hum etc that you won't get if you went balanced pre to single ended amp. The difference can be surprisingly large and audible even id there was no obvious hum present anyway. |
#5 | |
Hi Brett,
Though I agree that IT coupled PP throught sounds better still but I only had two 845s for my experiment! ciao James |
#6 |
Hi James,
As soon as I typed it I knew you'd pop in about your 6C45-845 amp. Because you need the tx to make it work, that makes it a 3 stage to my eyes ![]() It is a very unusual and special case amp. If you didn't have the bits on hand, or had another pair of 845's, would you have used that topology? Cheers Brett |
#7 | |
Hi Brett,
What a leading question! but your quite right, I came up with it to suit the parts I had. And that it worked so well was nice. I guess the proof is that the two 845s now reside in my Bass head...in PP Interestingly I'm still using the bipolar power supply to the 845s but without the interstage, just cap coupled and I think I am getting some ground line modulation... I think I'll redesign the twin output stage of my bass head. (I noticed this when using the head as a voice PA amp.) ciao James |
#8 | |
diyAudio Senior Member
Frank |
#9 |
Steve Bench uses the PP driving SE topology.
#10 |
diyAudio Moderator Emeritus
Hi Paul,
Welcome to the forum You'll like it here.Cheers, |
| OB push-pull | tinitus | Planars & Exotics | 3 | 22nd April 2009 11:17 PM |
| push pull | chainenoble | Subwoofers | 17 | 28th June 2006 04:35 AM |
| modify parallel push-pull EL84 to single push-pull | chungtat | Tubes / Valves | 12 | 3rd November 2005 11:25 PM |
| Push-pull amp with OP | piney | Solid State | 1 | 28th March 2005 02:34 AM |
| Double push-pull versus single push-pull | jraraujo | Tubes / Valves | 19 | 19th October 2002 12:23 AM |
