diyAudio Sponsor
Old 15th August 2011, 08:27 AM   #1
jule is offline jule  Slovenia
Default What happens If I use too weak output transformer?
I built 5W SE tube amp (ax84 P1)
I recycled an old tube radio - I used tubes(el84, rectifier), and both transformers.
But on the radio it said it had 4W.
The amp works fine, when I cranck it it squeals (but probably because bad wiring).
But I am worried what can happen with too weak OT? It could be that OT is more than 4W, but how could I detect the behaviour of weak OT?
Old 15th August 2011, 10:13 AM   #2
Dont' worry! First: I doubt if you are really getting 5W out of a class A SE EL84. Second: say you get the, it will only do this in the peaks of music reproduction, so unless you listen to full sine waves at max power you are safe.
my surname is indeed 'de Best': neither misspelling nor snobbism! Ask SY!
Old 15th August 2011, 10:15 AM   #3
Then I'm ok (it is a guitar amp).
Old 15th August 2011, 04:36 PM   #4
Hi Jule
than you are indeed safe! Good luck playing the blues!
Weak Output coit Digital Line Level 0 13th May 2010 06:33 PM
Acoustat 1+1 weak output danielm Planars & Exotics 20 7th February 2007 08:21 PM
why am I getting weak sub output? pasomark Subwoofers 18 21st December 2005 04:58 PM
Page generated in 0.07956 seconds (71.44% PHP - 28.56% MySQL) with 10 queries
