6L6GC/EL34 SE Stereo Design
Old 14th September 2003, 11:51 PM   #11
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Default Re: . . . .
Originally posted by Sch3mat1c
Forget to attach something?
Tim
Tim,
Do you mean to imply that the internal layout is uncluttered?
Old 15th September 2003, 12:07 AM   #12
bartr0n is offline bartr0n  United States
Sorry, don't know what happened. I'll try again...
Old 15th September 2003, 12:09 AM   #13
And the other one again ...
Old 15th September 2003, 12:59 AM   #14
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Well it must be very uncluttered, in fact, still in the parts boxes, including the chassis...
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 15th September 2003, 04:50 AM   #15
Ok, so I don't know what is going on, but I'm a newbie and still under moderation. I've tried to post two pictures under the size limit twice, I did attach them and I even checked once with the preview (and remembered to check if attached after that). So, any reasons why I would not be able to post pictures?
-=bart=-
Old 15th September 2003, 05:00 AM   #16
Hey, I wasn't moderated on that last reply! Woohoo. Let's give this another shot:
Old 15th September 2003, 05:03 AM   #17
Ahh, I get it -- the form did not like spaces in the file path. Here's the other one:
Old 15th September 2003, 05:10 AM   #18
Default Questions
So, what do you suggest I do to the exposed aluminum of the chassis to keep it clean? I'd rather not have to take it all apart and sand and spray ... and so on. Any ideas????
Just FYI, the little switches next to the octal sockets are to switch between ultralinear and triode strapped mode. The bolt next to the miniature socket is the chassis grounding point.
The ventilation holes also double for mounting holes, and other than that the chassis is very plain and boring. Any ideas on how to construct a bottom cover that raises and allows airflow into the amp??
Eventually I'll get to a schematic.
-=bart=-
Old 15th September 2003, 11:57 AM   #19
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
If you use the preview then the pictures don't get attached when you submit.
Don't ask me why...
Frank
Old 15th September 2003, 01:07 PM   #20
Elkaid is offline Elkaid  Canada
Elkaid's Avatar
Send a message via MSN to Elkaid
You could try diy anodizing. You only need a car battery charger and sulfuric acid. Anodizing will create a very tough protective coating on your aluminium. You can even use dye to color your parts, otherwise, your parts will keep their natural color.
Take a look at these :
http://www.focuser.com/atm/anodize/anodize99.html
http://floridamu.org/matt/general.html
I hope this helps !
6L6GC/EL34 SE Stereo DesignHide this!Advertise here!
Stereo Driver PCB for PP Amp (EL34/KT88)? Cobra2 Tubes / Valves 8 17th December 2010 09:50 PM
Stereo EL34 amplifier J_Hart_14 Tubes / Valves 25 25th July 2007 07:47 PM
stereo el34 + kt66? mholz Tubes / Valves 9 13th June 2005 04:44 PM
Whats a good 6L6GC Stereo Amp Project glenn Tubes / Valves 10 24th February 2002 07:07 PM
EL34 vs. 6L6GC for 1ST DIY Tube Amp? pjkunz Tubes / Valves 4 17th December 2001 02:51 AM
