diyAudio Sponsor
Old 14th August 2011, 03:17 PM   #1
tiefbassuebertr's Avatar
Default 6C33C based Version for Welter's Single Ended Amp (enhanced Forward Transconductance)
German's manufacturer for tube amps "Welter" use in his no longer available single ended power amplifier model "WT-500" (Welter Triode 500) a "6C33C"-based tube (WT530-S) with even exactly the same outline than the 6C33C from Ulyanov - see the pictures in the test report from German's hifi magazine "hifi exclusiv" about
http://www.welter-electronic.de/bild...b3_pdf_dat.pdf
The main different to the standart version is the enhanced value of the forward transconductance.
According the picture in this test report the type number is WT-530S, WT500-S or WT520-5.
The main advantage is the significantly lower demand to the gain-factor of the "front end" (VAS) stage so as it's tube.
Unfortunately this model can not be longer produce for the German manufacture "Welter" - so I have heard.
I want to know an overview from additional custom made versions of this tube in the outline of the 6C33C and the manufacturer, that produces currently this custom made versions for other companies (which develope and produce similar single ended amplifiers).
Additional I need all schematics of all Welter's "WT-500" versions (PM's you can send directly
to my e-mail address - kirschner-hifi@tiefbasswiedergabe.de)
Thank you for your efforts in advance.
Similar single ended amp (but with standart version of 6C33C and an additional 6C33C tube for voltage regulation) are the follow:
Lamm ML2.2 (Brooklyn, NY)
ML2.2 spec
Ultra High-End Audio and Home Theater Forum
Audio Federation - Audio Federation Blog Blog Archive CES 2011 - Lamm / Verity - High-end Audio Blog
Ayon Audio Spark III (Austria)
Spark III : Ayon Audio
PhaSt "triode SE" (Ukraine)
Phase Style Ltd. ::: PhaSt amplifiers ::: Verstärker ::: PhaSt triode SE ::: Deutsch
Phase Style Ltd. ::: ï³äñèëþâà÷³ PhaSt ::: Ïðîäóêö³ÿ ::: PhaSt triode SE ::: Óêðà¿íñüêà âåðñ³ÿ
Quest For Sound Bravo 2.3 (BENSALEM, PA 19020)
Quest For Sound - High End Audio
Prometheus Audio 6C33 SE Amp (Malaysia)
6C33 18Watts of Pure Triode Power
Almarro A318A and A318B interated amplifier (Japan)
almarro of Japan : products
http://www.almarro.com/pix/products/p2+.jpg
BTW - Very interesting to read is this topic from an other forum:
The short "6C33C Survival Guide"
GoodSoundClub - Romy the Cat's Audio Site - The short "6C33C Survival Guide".
More threads about the 6C33C:
6C33C – Lampa ipo ????? ? ??????? ????
Amplificador de PhaSe 1
Èíòåðåñíûå ñâåäåíèÿ î 6C33C - Ôîðóìû ÀÓÄÈÎ ÏÎÐÒÀË
6Ñ33Ñ - "íåò", 6Ñ33Ñ-Â - "äà" äëÿ çâóêà? - Ôîðóìû ÀÓÄÈÎ ÏÎÐÒÀË
Ulyanov currently manufacturing the 6c33C?
Graaf GM20 mods - help!
Availability of 6C33C tubes? I need some for OTL amps
6C33
Eintakt Röhrenverstärker mit 6C33 taugt das was - Allgemeines zur analogen Technik und Wiedergabe - Analog-Forum
Erfahrungen mit Welter ACPP 60 - Verstärker, Lautsprecher, Zubehör - Analog-Forum
6C33C-B. PP or SE ?
life in a vacuum
â»Ãà¨ç¡ÇѹËÂØ´ÂÒÇÀÒ¤ 2 SE6C33 ¤ÃѺ
single-ended power supply (12V) based active crossover r_s_dhar Car Audio 8 15th April 2011 08:44 PM
"CA-10", new Single Ended Power amp Device based on Aleph or ZEN ? tiefbassuebertr Pass Labs 1 29th September 2010 06:55 PM
Single Ended EL34 Amp dsavitsk Tubes / Valves 20 28th January 2007 08:48 PM
5 watts single ended amp renjiish Solid State 23 22nd January 2005 12:45 AM
single ended mosfet amp KlausB Solid State 11 26th February 2004 07:47 PM
Page generated in 0.09678 seconds (77.76% PHP - 22.24% MySQL) with 10 queries
