Electronic transformer filament supply
I am planning to use an 12V electronic transformer for halogen lamps for my filament supply for a guitar amplifier. Assuming I want to convert this to DC first, can I use bog standard 1N400X series diodes in bridge mode followed by an LC to rectify it? Any thoughts/answers would be highly appreciated.
For a quitar amp. I doubt you will notice any difference if you just stick with using
ac for your filaments. If you did go with a dc supply you would probably need to use
diodes with much higher current ratings. And a LC filter will probably give you closer
to 10V instead of the 12.6 you need.
Hello,
If you have the transformer in your hand try it. Current through a FWB rectifier looks more like pulses than waves, I am +1 with the idea of bigger and faster diodes. If you do not plan on a voltage regulator a CRC filter works well for heaters. You will need to adjust the resistor between the capacitors to dial in the output voltage.
DT
All just for fun!
