diyAudio Sponsor
Old 12th August 2011, 04:46 PM   #1
rongon is offline rongon  United States
Default CCS's for CCD line amp?
I was reading, found John Broskie's Constant Current Draw line amp article. That got me thinking that one can easily enforce constant current with CCS's. So, can I submit the following for criticism?
Has anyone built this?
Comments?
Thanks!
Old 12th August 2011, 06:06 PM   #2
DF96 is offline DF96  England
It is constant current until you attach a load. An amp without a load is not much use.
Old 12th August 2011, 06:18 PM   #3
Bigun is offline Bigun  Canada
Bigun's Avatar
yes, you have created a Constant current amp at least as effectively as Broskie. The CCS loads allow lower voltage rails than with resistors and being high impedance loads the tubes will be operating in a more linear fashion. Not everyone likes CCS's as it introduces an active element into the load but that's for you to decide.
I agree with DF96 about the limitation. Ideally you want the external load to be as linear as possible. In such a case, if you know what that load is, you can adjust the CCS on one or the other tube to achieve constant current still. If the external load is not perfectly linear it should still be a small enough load that you can achieve good current balance. I believe it's bad practice to operate the cathode follower with a heavy load if you want good sound.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 12th August 2011, 06:34 PM   #4
I sense an opportunity to learn something here...
Originally Posted by Bigun
I agree with DF96 about the limitation. Ideally you want the external load to be as linear as possible. In such a case, if you know what that load is, you can adjust the CCS on one or the other tube to achieve constant current still. If the external load is not perfectly linear it should still be a small enough load that you can achieve good current balance...
In my proposed application, the load would be a 1 meter interconnect, nothing special, going to a push-pull tube power amp's input, which would be the 270k ohm grid resistor for a 6N6P triode section.
Can you tell me what you mean by "a heavy load"? Do you mean the low input impedance of a solid state amp, or possibly a volume control pot/stepped attenuator?
What constitutes a "small load"?
Thanks...
Old 12th August 2011, 06:48 PM   #5
Bigun's Avatar
I can't quantify the impact of load on the sound of a cathode follower as I haven't done the experiments myself.
From an engineering perspective, I would suggest you want the current flow through the load to be <10% of the standing current flow through the cathode follower.
You caught my attention when you mentioned a 1 metre interconnect. This cable is a transmission line, it has capacitance and inductance. Most likely the capacitance is the main worry. It could cause a roll-off at high frequencies as the combination of the interconnect capacitor and load resistor form a classic low pass filter. You should google that and calculate the roll-off frequency.
Old 12th August 2011, 06:49 PM   #6
A question which must always be asked is whether a line stage is needed at all. 1m of interconnect is hardly a difficult load - you could drive it with a 50k volume pot. If you thought that your power amp might have a non-linear input impedance then a simple cathode follower would do. Do you actually need gain?
The low pass filter is created by the line stage output resistance with the cable capacitance, not the load resistance. In almost all cases of short interconnects the effect can be ignored.
Last edited by DF96; 12th August 2011 at 06:51 PM. Reason: expand to comment on Bigun's post
Old 12th August 2011, 06:53 PM   #7
Bigun's Avatar
Agreed.
Old 12th August 2011, 06:59 PM   #8
...Do you actually need gain?
Yes, in my particular case. I was experimenting and wound up making a 2-stage, DC-coupled, push-pull 2A3 amp that I like quite a bit. However, it takes 3.5V peak to get to full power, so just a bit more than the 2V rms from a CD player. I only really need a voltage gain of about 4X, but I know I'm not going to get that from a small triode. So I'll live with a voltage gain of about 15X. That's about what I've got going now, and it works.
BTW, I'm currently using a 6N6P triode section as a simple common cathode stage with unbypassed cathode resistor and 15k plate resistor, so I figure I'm getting about 12X voltage gain. I should measure it, I know.
Maybe I don't need a cathode follower at all.
Old 12th August 2011, 08:16 PM   #9
OK. Personally, I wouldn't worry too much about constant current operation. Just ensure the supply is properly decoupled.
Problem w/Concept CCD-2400 amp raljazz77 Car Audio 2 15th July 2011 06:27 PM
CCD-2400 Concept Car Amp raljazz77 Solid State 2 14th July 2011 10:04 PM
Need help with Concept Audio ccd-2400 amplifier mauguill Car Audio 2 5th February 2004 10:40 PM
Paralleling jfet CCS's rbroer Solid State 7 24th May 2002 07:50 AM
Page generated in 0.11091 seconds (78.76% PHP - 21.24% MySQL) with 10 queries
