For tube amps w/ high output Z - Parallel R cross spkr?
Old 12th August 2011, 04:42 PM   #1
rongon is offline rongon  United States
rongon's Avatar
Default For tube amps w/ high output Z - Parallel R cross spkr?
Hi there...
I have another question.
If you have a tube amp with no appreciable NFB from the OPT back to driver, so has a fairly high output resistance, would it help to reduce any impedance peaks in the speaker load? As in this:
Say this speaker has a ported woofer, and its impedance curve shows a 200 ohm peak at 25Hz and 170 ohm peak at 50Hz. Would it help to strap a 50 ohm resistor across the + and - terminals of this woofer, as in the drawing above?
200 || 50 = 40 ohms
170 || 50 = 38.6 ohms
Substituting a 30 ohm resistor gives this:
200 || 30 = 26 ohms
170 || 30 = 25.5 ohms
The 50 ohm resistor would parallel with the speaker's voice coil DCR of 5.5 ohms to yield 4.95 ohms.
30 ohm resistor paralleled with VC DCR of 5.5 ohms would make 4.65 ohms.
Maybe this parallel resistor idea would work better if the 4 ohm secondary tap from the OPT was used.
So, while this makes sense to me, I know from experience that there's an awful lot I don't know. So I'm asking... What have I overlooked? Any serious downsides to this kind of thing?
Thanks again....
Old 12th August 2011, 07:02 PM   #2
DF96 is offline DF96  England
The resistor would reduce the effective output impedance of the amp and so may help reduce frequency response variations. However, it does this by using up some of the power - in some cases most of the power. This is about the worst possible way to reduce output impedance!
Old 12th August 2011, 07:34 PM   #3
Bigun is offline Bigun  Canada
Bigun's Avatar
Hi rongon,
I believe you are thinking in the right direction - it's also my understanding that an amplifier without global feedback will not be able to control the voltage at the speaker as effectively as one with feedback and speaker drivers do not normally have very flat impedance curves. The word impedance is important, its not simply a non-flat resistance, the amplifier current and voltage drawn by the speaker can suffer from relative phase shifts too.
I don't know the answer, it's a complicated topic. I read about speaker manufacturers going to lengths to flatten the impedance. I found a couple of links that may be of interest:
Why and how of serial crossovers
The function of the impedance correction
hope this helps.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
For tube amps w/ high output Z - Parallel R cross spkr?Hide this!Advertise here!
Typical output impedance for tube amps Hylle Tubes / Valves 18 14th May 2017 12:03 AM
Drawing Load Line for Parallel Output Tube blue andry Tubes / Valves 4 4th September 2010 06:58 AM
High Zout tube preamps with ss power amps. ashok Tubes / Valves 24 15th December 2009 03:27 AM
What causes high THD in tube amps ? Borat Tubes / Valves 77 2nd September 2009 12:45 AM
Parallel amps & Parallel Voice coils? officeboy Multi-Way 7 26th May 2004 08:12 PM
Copyright ©1999-2017 diyAudio
