Cheap & Well Made Chinese SE EL34 Amp
Old 12th August 2011, 03:43 AM   #1
ttan98 is offline ttan98  Australia
Default Cheap & Well Made Chinese SE EL34 Amp
I like share with all of you the Single Ended amp I bought recently and it arrives today. I have not powered it up as yet. Take a look at the images here.
I paid US$200 plus $100 postage by airmail. I think it is a bargain. All the parts alone will exceed $200.
As you can see the chassis is very well made, chromium plated both top and bottom plate covers. The components are mounted on PCB and finish is very good as well. The rear view, you can see a black button it selects between the 2 inputs.
It does not come with a manual but the seller will provide you with a circuit diagram. The circuit is pretty standard, no feedback the driver is 6N3 connected in parallel to drive the EL34 which is connected in UL mode. It claims to give 12 watts I guess more like 10watts.
My intention is listen to it for a while and then modify it to accommodate KT88 tubes which I have few lying around.
You can see better quality images here,
Flickr: ttan98's Photostream
Old 12th August 2011, 03:56 AM   #2
Mr_Zenith is offline Mr_Zenith  United States
Mr_Zenith's Avatar
It would be interesting to see the schematic. Are the output transformers actually potted or are those just covers? Seems a nice find at any rate. Let us know how the future mods work out.
The name "TUBE" vacuum tube amplifier reminds me of the fad for generic products here in the states during the early '80's. They came in plain white packaging with the name of the item in bold black letters, along with the even-then-ubiquitous UPC codes. "SALTINES", "CIGARETTES" and "BEER" immediately spring to mind...
Old 12th August 2011, 04:49 AM   #3
HollowState is offline HollowState  United States
HollowState's Avatar
Trying to adapt KT88s to this amplifier will not be very fruitful. Even if your power transformer has the extra filament current necessary, you will find that to make them perform well you'll need higher bias voltage and higher B+ voltage as well. Without that you'll still only get about the same wattage output. Power out is proportional to power in. Also, the output transformer primary impedance will not be the best match. This is assuming the Chicoms designed it right for EL34s. KT88s may look prettier, but that's about all you'll gain. Maybe a "difference" in sound. Sorry if I'm a party pooper.
1944: 18 year olds storm the beach of Normandy into almost certain death.
2017: 18 year olds need a safe place because words hurt their feelings.
Old 12th August 2011, 05:24 AM   #4
Most o/p transformer will work well with EL34, even if I bias KT88 at lower current it should work well. A 3.5K or 5K transformer will work.
Old 12th August 2011, 05:28 AM   #5
I powered it up and it worked fine, very quiet and no hum.
I cannot release the circuit without the supplier approval, it is quite straight forward very similar to this,
DIY Single-Ended KT88 / 6L6 / EL34 / 6CA7 Tube Amplifier
except the 6N3 twin triode is connected in parallel to give more current.
Old 15th January 2012, 05:46 PM   #6
alexinthesky is offline alexinthesky  France
I just finised building the exact same amp I got as a kit for christmas (only difference is no PCB).
I replaced the 6N2J with 12AX7.
The amp is driving a pair of wharfedale 10.1( sensitivity rated 86Db).
Sound is good and no hum. Of course less power that with the gainclone LM3886 I had before.
One thing I have to say is that the power transformer is sizzling.
I tied the nuts holding it but no luck.
Do you experience the same?
Maybe the transformer is a little bit underdimentioned!
Alex
Old 15th January 2012, 08:20 PM   #7
mace1337 is offline mace1337  Netherlands
How much power supply filtering is there? Just those teeny caps?
Old 15th January 2012, 08:26 PM   #8
here is the schematic :
Old 15th January 2012, 10:00 PM   #9
Alain Poitras is offline Alain Poitras  Canada
Alain Poitras's Avatar
Very nice look and 6CA7/EL34 is a very good tube. I don't know about the output transformer quality but 200$ + 100$ shipping is a cheap price.
Old 16th January 2012, 07:35 AM   #10
OK, fixed the sizzling problem by tying more the bolds, all good now!
Now I have to listen to it for a while and see if I retube with better quality 12AX7s
Alex
Cheap & Well Made Chinese SE EL34 AmpHide this!Advertise here!
Building something better with a Chinese SE EL34B Amp DIY Kit VictoriaGuy Tubes / Valves 27 26th February 2015 08:21 PM
Suppo Audio -- New Chinese EL84 PP amp for CHEAP. bigjppop Tubes / Valves 431 7th February 2013 10:30 PM
Chinese EL34 amp to modify Cobra2 Tubes / Valves 53 10th April 2009 04:32 PM
cheap Chinese amp modules on ebay . Anyone know what they are ? jives11 Chip Amps 36 28th November 2008 04:35 PM
Cheap and Chinese KT88 SE amp andrew_whitham Tubes / Valves 46 19th May 2007 11:05 AM
Copyright ©1999-2017 diyAudio
