diyAudio Sponsor
Old 10th August 2011, 06:27 AM   #1
Dagwood is offline Dagwood  New Zealand
Dagwood's Avatar
Default E180F V EF184
Hi
I have a little headphone amp running Mullard EF80's or EF184 (much quieter).
Last night I found a nice pair of E180F tubes in my stock, would these be a straight swap seems the only pin out difference is that the screen is connected to Grid 3, all other specs seem close.
Any thoughts would be great, as I would like to build another as a preamp and have heard the E180F is a good choice
Cheers
If you keep digging in the garden of failure you will eventually find success
Old 10th August 2011, 05:01 PM   #2
Great choice! E180F-Phillips-gold pins - is my favorite pretube for my SE-s 2A3 and 300B! /it sister is amazing E186F/.
Old 10th August 2011, 06:14 PM   #3
Dagwood's Avatar
Thanks azazello
Do you think the screen connection to G3 will be an issue?
Old 10th August 2011, 07:28 PM   #4
http://frank.pocnet.net/sheets/009/e/E180F.pdf
Old 11th August 2011, 01:39 AM   #5
Dagwood's Avatar
Thanks for the link
Sorry, I must have not been clear?
I have had a look at the datasheet and noticed that the screen on the E180F is connected to Grid 3 ( pin 8 ) and wondered if it will work instead of a EF184? the EF184 has the screen on pin 6. Can these be swapped over???
Cheers
Old 11th August 2011, 02:47 AM   #6
alexg is offline alexg  Philippines
alexg's Avatar
Can you share your schematic of the E180F and 2a3? I have a pair of Philips 6688 with gold pins.
Old 11th August 2011, 06:20 AM   #7
Blaireau's Avatar
You can't directly replace EF184 with E180F, whithout rewiring the screen connection. -pin 9 from EF184 to pin 8 from E180F -pin 8 from EF184 to pin 9 from E180F -Cut wire from pin 6 (EF184) to ground, and leave te connection free. By the way, the Russian equivalent to E180F is 6J9P (6ж9п). These are very unexpensive and very good tubes. It's worth a trial.
http://constructions.f6fkn.com
Old 11th August 2011, 07:48 AM   #8
Dagwood's Avatar
Hi Blaireau
Thanks for that, It might pay for me to just use these on the preamp rather than trying to mod the headphone amp.
I guess my question was also aimed at the compatibility and people thoughts of the E180F?
I just had a look on Ebay for the 6J9P, your right at only $1.50 USD a piece!! Might try a few.
Cheers
Old 11th August 2011, 03:45 PM   #9
They are the same....., but sounding is some different, I have and I don't like 6J9P /close is 6J11P/.
Alexg, This is my SE 2A3-RCA. Plate resistor E180F now is 13 kohm /not 33 kohm/ and upper
resistor 12 kohm now is 3 kohm/:
https://picasaweb.google.com/1095707...13827582447474
Old 11th August 2011, 04:28 PM   #10
Blaireau's Avatar
6j9p are excellent when triode wired in an SRPP stage. To be true, I don't use "normal" stages in amplifiers anymore. SRPP is really the best architecture among all.
EF184/6EJ7 in Vox AC15 circuit. Who needs EF86? Cassiel Instruments and Amps 22 18th March 2012 07:16 PM
EF184 as ccs / design questions / spice model Rundmaus Tubes / Valves 9 9th June 2011 03:02 PM
Any EF184 users? Gluca Tubes / Valves 10 15th January 2010 05:40 AM
EF184 or (EC)L82 radio amplifier?! Michael68 Tubes / Valves 4 19th December 2007 05:40 PM
E180F triode-strapped. jim Tubes / Valves 15 16th September 2003 11:00 AM
Page generated in 0.10600 seconds (76.71% PHP - 23.29% MySQL) with 10 queries
