GM 70 Schematic needed!
Old 12th November 2012, 08:45 PM   #21
enzoastro is offline enzoastro  United Kingdom
Yeah stayed cool at roughly 280-300ma draw:-) the heater transformers and diodes were another thing!
Enzo
Old 28th November 2012, 07:44 PM   #22
widowmaker is offline widowmaker  Europe
widowmaker's Avatar
Send a message via ICQ to widowmaker GM 70 Schematic needed!
Originally Posted by enzoastro View Post
I used an antek 400-400 500ma toride for my gm70 amp, choke input gave mw 670v with the gm70's drawing 120ma each and 45ma for the driver stage, which is mu follower with 6e5p at 22.5ma/180v/3.7Vgk.
fitting a few small value caps at the ps input got me to 800v.
i now have the antek 500-500v 400ma to give 900v with very little capacitence, i like to think of it as choke input with snubbing caps ;-)
hope that may be of helkp
enzo
The value of 670V (and even 800V) is too low for GM-70.
If you want to get the best from GM-70 you have to use at least 1000V supply and anode current not more than 80-90mA.
Higher drawn current means also higher ripple in power supply, regardless of how big chokes and caps are used there.
The difference is quite big, it is tested already, believe me.
In my case I'm using for each channel one 400VA transformer with secondary 1.05kV AC (1050-0-1050 full wave).
Russian damping diodes 6C10P as a rectifier, then RC(100R+20uF) and two LC filter(20H+80uF) in series. Ua-c is about 1150V (Ia=85mA),
about 120V at cathode resistor and about 30V at output transformer.
Anode load is 10k.
Dampers 6D22S are not suitable for high end amplifiers due to their very low internal resistance (this is not a solid state device, right ).
For sure russian 5C4S/M is one of the best rectifiers for high end audio, but in our case it is useless because of its relatively low reverse anode voltage.
High Tension Wires Department
Directly heated glass jars (vacuum filled)
Old 28th November 2012, 08:05 PM   #23
Thanks for the advice;-)
Its running at 930v 85ma/gm70 now
i found whats made the biggest difference so far was the coleman filiment regulators and power supply caps, and have to say i like low impeadence power supply sound, not fasionable i know!
I do have a few 10h 350ma chokes so may try another LC stage after the cLC or even a ss regulator. Size and heat is the limiter for me, im trying to keep to 60 x 30 cm for a 2 channel chassis, not inc the heater supplies.
enzo
Old 1st December 2012, 03:28 AM   #24
djn is offline djn  United States
djn's Avatar
Can you say more about this. I am planning on using the 6D22s.
GM 70 Schematic needed!Hide this!Advertise here!
GM-70 Build Issues Pyre Tubes / Valves 95 28th July 2012 08:29 PM
FS: GM70 ( GM-70 ГМ-70 ) Russian audio triode radiostar Vendor's Bazaar 0 23rd February 2011 06:12 PM
Pioneer A-70 schematic needed!!! pejinm Solid State 0 24th February 2006 04:12 PM
6C33C and GM-70 Colt45 Tubes / Valves 21 20th November 2002 11:38 PM
