diyAudio Sponsor
Old 8th August 2011, 02:49 PM   #1
Default 7027a testing
Just arrived here and left a short introduction. Looks like a great forum.
This is my question: When I'm out checking on possible tube buys I take my little EMC 213 tester with me for quick quality and short checks before buying. Problem I have is there are no settings listed for 7027/7027a tubes. They will not test properly on 6L6 setting, I assume because of the 2 extra pins. Can someone tell me what those settings would be or where I could find them? I'm having no luck at all..thanks..bruce
Old 8th August 2011, 08:23 PM   #2
7027 is electrically the same thing as a 6L6 but has higher voltage / dissipation ratings. You are right about the two pins, that is probably giving you troubles on testing. They would be pins one (1) and six (6). If you have a tube tester that you can select what the different pins of the tube under test see, make sure pins 1 and 6 are NOT connected to anything. Then it should test like any other glass 6L6. The other thing you can do is cut pins 1 and 6 off of the 7027 and then it will test correctly on the 6L6 setting. This will devalue the tube though.
Daniel
Old 8th August 2011, 09:06 PM   #3
SY's Avatar
Dan, specifically, it's a slightly re-pinned version of 6L6GC. One can rig up an adapter socket to use it in 6L6 tests or amplifiers.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 9th August 2011, 12:05 PM   #4
SY..could you tell me how to do that?
Old 9th August 2011, 12:42 PM   #5
SY's Avatar
Sure. Get yourself an octal plug and an octal socket. Using a relatively stiff wire, you can connect the two, with the socket floating about 1 cm or so above the plug. Care must be taken when plugging and unplugging! If you're a real studboy, you'll find some high voltage potting material and make it into a monolithic assembly which will be considerably less fragile.
Old 9th August 2011, 01:23 PM   #6
Tom Bavis's Avatar
In most cases, 7027 and 6L6GC are interchangeable. Amps with 7027 seldom used pins 1 and 6 (but check!). 6L6 amps may have used pins 1 and 6 as tie points - move these wires to a new terminal and either will work. I don't have an EMC tester any more, but I believe it has a switch corresponding to each pin. Set for 6L6, set switch #6 to the same position as #5, set switch #1 to the same position as #4, and test. Pins 1 and 6 may test "short" - ignore.
Old 14th August 2011, 12:52 PM   #7
Thanks Tom that worked perfectly!
Started work on my stereo 7027a PSE amp 807tubenut Tubes / Valves 7 23rd January 2011 08:51 PM
Looking for PP 7027a shematic 807tubenut Tubes / Valves 1 21st August 2010 07:52 PM
7027A with tubelab simple se pforeman Tubelab 10 8th November 2009 02:48 PM
testing, testing 123 neil_kaye Full Range 0 25th December 2005 08:21 PM
WTB 7027A Tubes webercarbmann Swap Meet 0 24th November 2002 09:37 PM
Page generated in 0.09241 seconds (74.82% PHP - 25.18% MySQL) with 10 queries
