anyone know the dimensions of a dynakit st-70 pcb?
Old 8th August 2011, 09:28 AM   #1
KX36 is offline KX36
Default anyone know the dimensions of a dynakit st-70 pcb?
I'm just doing this for practice designing PCBs with valves on, no immediate plans to produce this, but I was wondering if anyone knows the length and width and mounting hole positions (hole to hole spacing or hole to edge dimension, as long as I can work it out I'm not fussy ) for the PCB on this old favourite? I'd really appreciate it.
Matt
Old 8th August 2011, 10:26 AM   #2
Burnedfingers is offline Burnedfingers  United States
try this
conversion
76mm=2.99in
70=2.756
3.5=.137
29.2=1.1149
160=6.29
101.6=4
Its useful for making your own driver boards.
Old 8th August 2011, 11:18 AM   #3
Dim from front to back is around 3.3 inches
Width is around 6 11/32
Old 8th August 2011, 12:13 PM   #4
Bob01605 is offline Bob01605  United States
Bob01605's Avatar
Send a message via AIM to Bob01605
The question asked by poster KX36 is "anyone know the dimensions of a Dynakit ST-70 pcb". The dimensions given by poster 6BG6GA are not quite accurate and may reflect the size of the chassis cut out that the board fits. The board itself is somewhat larger than the chassis cut out.
The original Dynaco PC-3 driver board (Dynaco part # 557003) is 3.25 inches front to back by 6.50 inches side to side. The mount holes on the board are 4.00 inches apart side to side and 3.00 inches apart front to back. Each mount hole is exactly 1/8 inch on center from the edge of the board.
Bob Latino
Old 8th August 2011, 01:06 PM   #5
Thanks guys, that's awesome. The cutout dimension is useful too, perhaps more important than the actual board size. I'm really impressed with how quick and useful all the responses I've gotten to my questions here have been!
Old 8th August 2011, 09:42 PM   #6
I gave you the cut out dims. Sorry about that. Anyone can plainly see after looking at the overall that the dims I gave were the cut out. Its very easy to print out the cut out size and use it for a template.
I use that for making my boards from a solid piece of PC board material without copper.
The dims for the stock board and the aftermarket boards do vary in length and width by as much as .020-.030 or more. Dims between different driver board manufacturers do also vary. I have three in front of me all different board designs and all vary in overall.
Width is around 6 11/32 These are aftermarket nominal dims.
Old 10th August 2011, 05:46 AM   #7
beetel is offline beetel
Could some one tell cutout size and PCB size for Dynaco ST-35 amp too.
anyone know the dimensions of a dynakit st-70 pcb?Hide this!Advertise here!
Transformer Rattle & Hum issue - Dynakit ST-70 brilliantblue Tubes / Valves 5 26th July 2011 01:47 PM
KTA-HiFi ST-70 pcb or marantz 8b. HiFi build iglehart332 Tubes / Valves 18 18th March 2011 02:19 AM
ST-70 Dynakit Stereo PC-3A Assembled john65b Swap Meet 3 15th February 2011 02:18 AM
College-proofing an ST-70 (aka autobias+ST-70) antiquekid3 Tubes / Valves 15 13th June 2010 03:37 AM
WANTED: Old pcb of St-70 Geek Swap Meet 0 16th October 2008 12:31 AM
Copyright ©1999-2017 diyAudio
