diyAudio Sponsor
Old 7th August 2011, 09:38 PM   #1
Default dc coupled volume pot value
My triode input is 200k grid to ground with a 1k stopper. Im installing a usb dac that does not have a dc offset (less then 1mv due to charge pump output). If everything is dc coupled do i just pop in a 20-30k pot (1/10th input rule) and call it a day. I know dc coupling the pot to the amp could change the behavior of the pot due to the 200k resistor, but it should change it much as all since the resistor is so high compaired to the pot, correct?
My only other thought was to clip the 200k resistor and replace it with a 250k pot + a 1meg or less "safety" resistor after it incase the pot wiper lost contact.
single push volume pot, volume up/down via a button. dragonxwas Analogue Source 4 2nd June 2011 06:56 PM
Valve buffered IGC - volume pot causes DC offset, crackling gaplessophile Chip Amps 29 3rd July 2009 12:02 AM
Opamp that can be dc coupled ? beppe61 Solid State 37 20th January 2008 08:21 AM
Volume control : - pot' or pot' variable feedback resistor (gain) ? ash_dac Solid State 5 1st August 2006 05:07 AM
Gain pot instead of volume pot boyofwax Solid State 5 14th February 2004 02:37 AM
Page generated in 0.07014 seconds (67.78% PHP - 32.22% MySQL) with 10 queries
