| diyAudio Sponsor | ||
here there is a solid state section and tubes section
but not HYBRID section
visit my best audio idea http://www.esafono.it/DACTONE.htm |
#2 |
Stee,
You are a dynamo of ideas. Well, this latest one is kind of funny because using a tube as a phase splitter is how JLH started - his design came after the Williamson tube amplifier which had a tube phase splitter. JLH made a transistor work as a phase splitter. I'm not sure what you have is a good idea - unless you use low voltage tubes. Otherwise there is a large voltage between anode and cathode when operating most tubes in their optimal set up. In this case your design would end up with a very large voltages across the lower transistor which means quite a lot of power dissipation ? The usual approach to a JLH hybrid is to to use a PNP phase splitter with the usual NPN power output transistors to make a unity gain follower and then drive it with a tube VAS. But the JLH is purported to sound so good that it doesn't bear much need for improvement ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#3 |
The detail provided by the valve is impossible to achieve with the bipolar
it is typical to use them as preamps The final transistor should be quasi-complementary (see modern trend link) so this should provide an ideal sound mixing you help me? MX50X2 Class AB Audio Power Amplifier AMP Kit 2-Channel | eBay
#4 |
If you want a tube driven quasi-complementary hybrid you might look at this:
http://www.wimdehaan.nl/downloads/te...lnishiki41.pdf
| Enhanced Tube's performance | Stee | Tubes / Valves | 3 | 13th June 2010 06:07 PM |
| Judging a tube's condition | db! | Tubes / Valves | 2 | 11th February 2010 03:46 AM |
| My wacky idea for a hybrid horn loaded woofer/planar widerange hybrid loudspeaker. | Spasticteapot | Multi-Way | 0 | 30th November 2006 04:16 AM |
| tube's tempdrift | SemperFi | Tubes / Valves | 1 | 3rd April 2002 12:43 AM |
| Page generated in 0.08517 seconds (68.62% PHP - 31.38% MySQL) with 11 queries |
