| diyAudio Sponsor | ||
Is anyone familiar with these? I did a search and go t only one hit on a SS version.
It appears that late in their production they made one chassis that was used in the TV console and the stereo console. The one I scored today ($32.00) is a console stereo, but there is an input jack on the chassis for TV. All the tubes are marked Curtis Mathes, Japan. I slowly brought up the B+ on the caps to see if they would reform, and they looked good so I did the light bulb and variac power up. Everything looked good so I tried the FM stereo and it locked in to a strong station, but is a bit distorted. With the selector on tape no input and the volume on max the hum is not too bad. B+ at first stage is 350, with 325 on the plates of the (SE) 6BQ5s. Ripple on the first filter cap is 4Vrms, with 0.3Vrms on the next filter, and less than 10mVrms on the two final (it splits) caps. I connected a CD player to the tape input and it sounded much better. It is nice that it is an integrated receiver, if it is possible to align the FM to get rid of the distortion. |
#2 |
I don't know about the receiver, but I think it's cool that you have a garden hose nozzle AND a piston on your workbench.
Single-Ended Tube Amp Kit |
#3 |
There is lots of other weird stuff there that you can't see. On the left is a 1960s Pastis glass from Pernod.
Piston is from a 1000cc 1975 Harley Davidson XLCH. That garden hose nozzle does not get used by anyone but me. Mine! Solid brass and 30years old +. Actually it is difficult to open so I let the significant other use a squeeze nozzle. I still like the old style hose nozzle. |
#4 |
Cool Whip and beer?????
#6 |
The layout of this one looks very similar:
Receiver with Amplifier 29C1 (Ch= 29C1) Radio Curtis Mathes CURTIS MATHES model 29C AM FM Stereo receiver Sams Photofact manual :: VintageAdsAndBooks.COM CURTIS MATHES 29A1 & 29C1 RECEIVER PHOTOFACTS PHOTOFACT | eBay
#7 |
This looks like it has the oil caps, and none are leaking.
It is a model 29FMX, which I believe is one of the last ones made before switching to SS. In part this is based on the cabinet construction, which was veneer covered particle board. From the adds I've found on several sites, up to the mid 60s they were advertising solid wood construction. It looks like they had a basic design that they used in a wide variety of products, and kept improving the basic design over at least a decade. |
#9 |
Pernod Pastis is no where what it should be. There are a few Absinths that are drinkable.
#10 |
Sams Photofacts lists model 29C in 635-4, 29A1 and 29C1 in 636-5, and 29D4MX in 641-9. All are from 1963.
| Stan Curtis | wjlamp | Solid State | 0 | 25th August 2010 12:57 PM |
| stan curtis 60w class a | jamesfeline | Solid State | 16 | 6th May 2008 02:47 PM |
| Telefunken Console Tube Receiver (stereo): $75 | pjanda1 | Swap Meet | 5 | 22nd September 2007 10:21 PM |
| dvd player video straight to tv or through a/v receiver? | TuroK27 | Digital Source | 1 | 30th May 2005 01:28 AM |
| Page generated in 0.09521 seconds (78.21% PHP - 21.79% MySQL) with 11 queries |
