diyAudio Sponsor
Old 5th August 2011, 02:06 AM   #1
jeapel is offline jeapel  Canada
Default 2 x 6as7 -> u=?
hi
I would like to know:
6as7 -> pa max=13 watt with a low u=2
if i put 2 x 6as7 together pa max will be 26 watt but
u stay 2 or go up to 4 ?
thanks
Old 5th August 2011, 02:56 AM   #2
smoking-amp's Avatar
For 2 in parallel, the Mu stays the same at 2.
Ohms Law V = I R
Old 5th August 2011, 11:00 AM   #3
thanks smoking-amp
FOR REGA Turntable>>> The heavy weight + Vta adjuster+ceramic ball prooptiki Swap Meet 1 22nd May 2010 05:57 PM
Multi-DAC: Lynx AES16 -> DIR9001/SRC4392 (-> SRC4192) -> PCM1794A novec Digital Line Level 11 11th May 2010 11:57 AM
> Audio <> music <> quick <> synergy <> angst>? rick57 Everything Else 0 4th May 2007 04:03 PM
&gt;&gt;&gt; cheap 50,000uF 60V capacitors here &gt;&gt;&gt; Lubomir Swap Meet 0 1st February 2007 03:36 PM
Page generated in 0.06009 seconds (67.58% PHP - 32.42% MySQL) with 10 queries
