diyAudio Sponsor
Old 4th August 2011, 03:39 PM   #1
emosms is offline emosms  Bulgaria
Default ecl11 - ecl86 replacement
Is it possible to replace the ECL11 tube (tetrode)
ECL 11, Tube ECL11; Röhre ECL 11 (ECL11)
with ECL86 (pentode)
ECL 86, Tube ECL86; Röhre ECL 86 (ECL86)
ecl86 is pointed as a successor of ecl11
Here is the schematics>
View image: condor 965wk schema
- I don't know what to do with the supressor grid, which is connected to catode inside the tube
Old 4th August 2011, 04:13 PM   #2
the_manta's Avatar
Hi !
Yes you can do that. Those adaptors were quite popular (in germany for sure) and they were available in shops. Look here, that's what you need: Inter ECL11 E / ECL 11 E Radio-Röhre, ECL86 + Adapter | eBay
Since the 965WK is a Superhet, the ECL11 is only used for low frequency amplification and can be substituted with the ECL86. You will even get more gain due to higher µ of the triode section. You don't have to worry about the supressor grid in the ECL86. It is connected to the cathode internally, that's where it should be connected.
There is a fabulous homepage where you can read more about using replacing old tubes (for radio use, nothing useful for audiophools here): Umsockeln_von_Roehren
Have fun with your radio, it's lovely one.
Old 4th August 2011, 08:59 PM   #3
Thanks for the link!!!
tubes.rs
facebook.com/tubes.rs
stern's ecl86 amp stevewrigley Tubes / Valves 12 26th March 2011 10:50 AM
ECL86/PCL86 Schematic TubeKing Tubes / Valves 17 5th November 2010 08:11 AM
ECL86 preamp? Hanzwillem Tubes / Valves 23 16th June 2007 11:45 PM
Help with 6GW8/ECL86 tubes?? fluckscapacitor Tubes / Valves 5 11th October 2005 02:46 AM
Parallel PP ECL86 amirmk Tubes / Valves 5 19th August 2005 09:26 AM
Page generated in 0.07981 seconds (70.04% PHP - 29.96% MySQL) with 10 queries
