12B4A as tube buffer? - diyAudio
Old 25th August 2003, 08:44 PM   #1
G is offline G  United States
G's Avatar
Default 12B4A as tube buffer?
Hi all. I was looking around for a low mu triode to use in a buffer/volume control and came across the 12B4A. Frank I believe I've seen you include this tube in a preamp that you designed and posted. I may be mistaken though. It looks like 300V on the plate with a 5K resistor on the cathode and a 500K grid resistor would give you a pretty good buffer with low output impedance. That would be with 34 mA through the tube. The signal would be taken off of the cathode of course. Any opinions?
Gavin
Old 25th August 2003, 08:45 PM   #2
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Go for it. Looks nice and linear, like a single mini-6AS7. But with mu=5, it'll drop a lot of signal.
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 25th August 2003, 09:07 PM   #3
diyAudio Senior Member
fdegrove's Avatar
Gavin,
I think you mean the 12BH7A, an ECC82 on steroids.
The circuit was a White CF.
If you want a good buffer with high current capability then a penthode is often desirable.
The 12B4A is a very fine tube I like alot and cheap too.
What kind of CF do you have in mind?
Frank
Old 25th August 2003, 09:08 PM   #4
Fuling is offline Fuling  Sweden
Oh, my favourite little triode!!!
If I had to live with one tube only for the rest of my life, it would be the 12B4A!!!
I have wet dreams about a 12B4A > IT > 12B4A > OPT amp.
Some day...
Well, enough about that.
I too have plans for a line stage using this tube.
It will probably be a common cathode stage using either plate chokes or 2:1 OPT:s.
As I said its an excellent tube, especially considering the price.
Old 25th August 2003, 10:14 PM   #5
fdegrove's Avatar
Default Santa's Early...
Ironman, aren't you?
Have you tried the 6C19P? Not bad either.
Gavin.
Here's something you can even drive your speakers or cans with if you add a 220F cap to the output:
P.S. The cap at the input isn't necessary if the source has an output cap and you use a switched attenuator as indicated.
Frank
Old 25th August 2003, 10:23 PM   #6
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Default Re: Santa's Early...
But if you remove that 220n, won't it upset the biasing of the stage?
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 25th August 2003, 10:26 PM   #7
Yeah, Im on a long and winding (!) way away from plate resistors and coupling caps
Nope, I havent tried 6C19P. Cant find a local source for them.
Sad it is.
That White follower looks like something that almost could drive my 811As in class A2, I think.
Old 25th August 2003, 10:30 PM   #8
Brett's Avatar
The 12B4A is a great tube. The cct Frank linked would be fine if you need no gain, but if you do want some, try a Pimm BBMCCS and run it as a mu stage. Gain is around 5 and the output Z should be below 200R.
In a line stage, run DC heaters as they seem to be sensitive to a bit of hum IME.
My fave op-point (grounded cathode) is 120Va-k, 30mA. They seem to last quite a while here too.
Old 25th August 2003, 10:37 PM   #9
fdegrove's Avatar
Default Re:Santa's erly...
But if you remove it, won't it upset the biasing of the stage?
I know, it should...
BTW, the attenuator is a constant Zo series attenuator so the bias shouldn't change by changing positions of the volumesetting.
I never really measured it with and without it, prefer the way it sounds without the cap so something must be right.
If you feel it should be left in then I've no problem with that.
P.S. Fulling, I tried it to drive a 812 and it works great.
Frank
Old 25th August 2003, 10:37 PM   #10
G's Avatar
Hi Frank. I was looking for a simple cathode follower to use as a volume control. Kind of a passive "preamp" without the impedance problems. Sch3matic I'm not great at caculating gain and I don't have a lot of experience with CFs. What gain figure do you see for the schematic below? A cathode follower should have a "gain" of about .8 or so shouldn't it? Please excuse my ignorance with this circuit.
Gavin
Tube buffer before pre-amp/amp? Destroyer OS Instruments and Amps 2 9th January 2009 07:09 PM
12B4A tube amplifier with output transformers Burnedfingers Tubes / Valves 3 11th December 2003 10:46 AM
Tube Buffer IGC - need help .... Will Chip Amps 22 21st November 2003 07:54 AM
Tube buffer NickC Tubes / Valves 3 9th May 2002 11:20 AM
Copyright 1999-2017 diyAudio
