A question of bias...
Old 26th August 2003, 03:16 AM   #11
Brett is offline Brett
Brett's Avatar
Originally posted by fdegrove
Those few, and you can count me in, are actually in the good company of RCA who actually described what was going on in their manuals.
I much prefer the output pair to be well balanced, and a CCS in the tail is excellent. If you want some imbalance, and I'm not entirely convinced by what I've heard so far, then do it in the gain/driver stage.
I have the article somewhere in my archives...
I'd like to read that....
Old 26th August 2003, 03:45 AM   #12
On Hiatus
SY's Avatar
Brett: Most driver/gain stages have some degree of imbalance to begin with. You can polish a turd by introducing a complementary imbalance in the output stage.
I suspect that we'd agree that it's best to make the whole shmeer well-balanced to begin with so that we don't have to do unstable tricks like that in the first place.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 26th August 2003, 03:52 AM   #13
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Originally posted by SY
polish a turd
Mods can say that!?
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 26th August 2003, 03:53 AM   #14
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
And you will...
WHEN A SEE SAW IS JUST THAT...
Frank
Old 26th August 2003, 04:04 AM   #15
fdegrove's Avatar
Ever specced a xformer and measured what you actually paid for?
Ever wondered why those tubes that measured so well on the the tester didn't match so well in the amp?
Shall I go on? Or shall we open up a book and dig into AC current flow?
Maybe I should publish one of those rags too?
Come on you guys, use those little greys cells for a change.
Frank
Old 26th August 2003, 07:02 AM   #16
Brett's Avatar
My preference is to have it balanced well all the way, usually with CCS's in the tails. However, fiddling with a paraphase splitter has been interesting. At about 5% imbalance it seems to fatten up a little bit (more robust sounding) with no real negative sonic consequences, so far. I'm still in the courtship stage with this topology so after the flush or harmonic hormones has worn off, I may find myself having an epiphany, finally understanding why the Scots call them lassies, and saying a quick farewell.
Old 26th August 2003, 01:11 PM   #17
On Hiatus
SY's Avatar
Congrats, Brett, you've discovered the secret of SET magic! And with open eyes yet, which puts you one up on most people.
Frank, yes, I've done one or three of those measurements. The real issue I've seen in balance at the low and mid frequencies versus the balance at high frequencies. The latter can be brought into line, if need be, by some compensation capacitance. Or, if you've got a triode class A stage, by neutralizing caps.
Old 26th August 2003, 10:49 PM   #18
Brett's Avatar
LOL. I don't think that's all the SE 'magic'; there's an o/p Z that modulates with the signal waveform, low inductance OPT's and often really poor PS design too.
The EL84 amp I mentioned above is nice, but isn't a patch on the PP amp I use as my main unit. I was just surprised (again) at the effect it had. The amps going into the bedroom system so it will be fine driving a crappy Tannoy Red.
Old 27th August 2003, 04:53 PM   #19
DrG is offline DrG  South Africa
Default back to bias
Firstly: thank you analog_sa for the Beard circuit.
OK, so CCS's are a possible bias solution. Now has anybody considered differentially driving an output tube as follows (sorry, can't supply drawing right now...)
P-channel FET in cathode circuit, using a small separate CCS to fix Vgs and therefore Is. Drive gate and tube grid equally, in anti-phase from a LTP...
I'd like to hear the tube guru's input on this (no pun intended)...
Old 27th August 2003, 05:22 PM   #20
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
But did you ask for perfect balance? It's not actually a problem to make transformers that have (near as dammit) perfect balance, and that's why broadcasters use them for microphone and line-level signals in noisy television studios. Exactly the same techniques can be used in an output transformer, but if you don't ask, you don't get.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
A question of bias...Hide this!Advertise here!
F5 bias question richD Pass Labs 12 4th March 2013 01:57 PM
CCS bias question alexmoose Tubes / Valves 4 22nd July 2006 06:21 PM
Bias pot question Burnedfingers Tubes / Valves 1 1st January 2006 03:49 PM
a75 bias question SteveG Pass Labs 3 17th January 2002 12:06 AM
