| diyAudio Sponsor | ||
I came across a schematic of an EL84 SE, the cathode bypass is connected to the 8 ohm tap of the OPT secondary.
Haven't encountered this before, so, why is it connected to the 8 ohm tap of the OPT's secondary? Thanks. |
#2 |
It's called cathode feedback, just like in the attache file. Basically it reduces distortion greatly, increases damping factor (tighter bass) but needs more input voltage ( just because it's feedback). I did this on my RH807 and it plays very good. Rgds, Eric |
#3 | |
Thanks. BTW, the schematic you posted is the one I was looking at! |
#4 |
Tubelab does this on the Simple SE Simple SE schematic
I tried it on a pentode headphone amp, and was not happy with the sound: ecp.cc
http://www.ecpaudio.com |
#5 |
| Appropriate replacement OPT for Fisher 30-A with 2.5Ohm Secondary | awroethlisberger | Tubes / Valves | 9 | 8th October 2010 01:19 PM |
| Cathode Feedback from Secondary for PP Amp | gingertube | Tubes / Valves | 22 | 1st July 2009 11:45 PM |
| Zenith Console Opt Question, Odd Secondary | Trout | Tubes / Valves | 10 | 3rd October 2005 02:20 AM |
| Why a Zobel network across OPT primary or secondary? | ray_moth | Tubes / Valves | 6 | 4th March 2005 10:26 PM |
| Polyprops as cathode bypass | s2kov | Tubes / Valves | 10 | 3rd December 2004 08:56 PM |
| Page generated in 0.09140 seconds (76.83% PHP - 23.17% MySQL) with 11 queries |
