| diyAudio Sponsor | ||
I have a power transformer rated 240Vac, 80VA that I would like to use...please see attached dwg, the B+ at full load is about 300-320Vdc and 200mADC is available for a stereo application. I have never built PP so maybe that would be nice. So far my amps are; Chinook (SET 2.5W) with 13FD7 RH84 (6BQ5) RH807 (807) I'm presently working on a 12AV5GA SET (triode strapped pentode) with 6N6P driver and CCS on driver. If you have any idea as to what I can use my power transformer for please let me know. TIA, Eric |
#2 |
Any help ?
I do not know tubes characteristic enough to know which output tube I can use with such available B+ and Ia, can a design be done using GU-50, GU-19, 4P1L with my power transformer ? Is some one know a very goo sounding tube please be my guess and let me know. TIA, Eric |
#3 |
With your b+ you could do most el84 PP setups.
tubelab simple pp the baby huey the red light district the podwatt |
#4 |
You only have 100mA for one channel left then.
1625 is a bit tight calculated. But EL84 is fine (Class AB) There are kind of million circuits for PP EL84 available, so choose one. |
#5 |
I forgot to mention that I bought a few months ago a set of CXPP25 8K OPT from Edcor, I will use them to built a nice sounding EL84 PP, so for now I would rather avoid building a EL84 power amp. Any idea with more odd tube like RCA 832, GU50, etc...
Thanks, Eric |
#6 |
single ended GU-50, using 8k SE OPT... use 6AU6 to drive it with local feedback..
Edit: Just noticed you had a RH807, you could try a RH-50, but using GU-50 instead and instead of a 12AT7 as driver, use a pentode driver eg 6AU6 or EF86 or even EL-84 as a driver. You might like it... I certainly like my pentode driven 6E5P driven GU-50 with local feedback :-) Last edited by quikie22; 2nd August 2011 at 04:15 PM. |
#7 |
Hi Quikie22,
I already have a few 6AU6 but EL84 driver sound even better ;-) GU-50 with EL84 or 6AU6 driver with local feedback sure sound like a win win situation, can you share some feature of your design like operating points of driver and output tube because I used the 6AU6 as driver on my RH807 and couldn't get the amp to sound right... Thanks in advance, Eric |
#8 |
Looks like the 6E5P (which I didn't know about) is a heck of a driver, you could use it to drive GU-70 or 6C33C...nice to know. I wonder how the 6N6P compare to the 6E5P as far as driver...
Thanks ! Rgds, Eric |
#9 |
Hi all DIY's,
So far I have found a 6E5P/GU-50 SET Amp schematic which is fixed bias with Ia around 80-85mA for the GU-50 and ?? for the driver..which is quite a tight fit for my 100mA/channel... Rgds, Eric |
| Pulse transformer recommandation (PE-65507) | etoiledusoir | Digital Line Level | 0 | 12th February 2011 05:58 PM |
| Fostex BK108 3'' Horn for Tangband W3-315E recommandation needed | jockel77 | Full Range | 3 | 30th September 2010 08:41 PM |
| Brand recommandation for high end bookshelf | harrisni | Multi-Way | 3 | 3rd December 2006 02:41 PM |
| Page generated in 0.08308 seconds (82.32% PHP - 17.68% MySQL) with 11 queries |
