| diyAudio Sponsor | ||
I think I will try it like this
probably gets less 'google hits' than my other thread |
#2 |
reading about Van Scoyoc cross coupling, I thought why not combine it with above cathodyne
haven't seen this anywhere, so I guess it won't work
#3 |
Needs some caps after the cathodyne for voltage isolation. Main problem will be the low and varying impedances seen by the cathodyne (due to driving the output stage cathodes) especially with the outputs operating in class AB.
With some Mosfet followers to drive the output stage cathodes inserted in between it could work.
Ohms Law V = I R Last edited by smoking-amp; 2nd August 2011 at 05:25 PM. |
#4 |
Is Van Scoyoc the same as Blumlein garters?
Listen to the music through the stereo, not the stereo through the music. |
#5 |
No. The Van Scoyoc was an overly complicated phase splitter, and the Blumlein Garter circuit was a cathode biased arrangement that automatically balanced plate bias currents. Two different things.
#6 |
I guess uoy refer to the cathode follower design
I believe it was done because of the need for a low impedance drive from what I understand a trafo or interstage was originally used to 'drive' the Van Scoyoc splitter the more complicated cathode follower design was implemented instead of the 'simpler' trafo thats why I thought 'hey, cathodyne has low impedance too', right ? but in my suggestion its the output stage that have cross referenced cathodes, and not the phase splitter so it might be a completely different thing but I don't know |
#7 |
ok, different approach
transformer/autoformer used as phase splitter seem to become more popular this one uses a relatively cheap interstage in a parafeed manner and the secondary is used to cross reference output cathodes, in a kind of Van Scoyoc style I suppose the IT is less critical this way but is it possible ? |
#8 |
and, slightly different
#9 | |
They didn't have anything that could have served as a CCS for an actively loaded LTP. They were trying to solve problems that have much simpler solutions today. Also, any time you have cross coupled feedback, you have a potential astable multivibrator. |
#10 |
The circuit in post 8 is looking better. The coupling xfmr needs to have a low output Z to drive the cathodes. And as Miles mentioned about cross coupled feedbacks turning into a multivibrator, the turns ratio for the low Z out xfmr would need to be low enough to keep the loop gain around the cross-coupled loop less than 1. Ie, the cathode currents must not excite their own grids with enough voltage to keep it oscillating. With the loop gain kept just below unity though, it may bootstrap the input impedance to eliminate loading on the 1st tube stage. Might be an interesting design concept.
Ohms Law V = I R |
| Humble Statement | wigginjs | Multi-Way | 12 | 19th December 2007 04:11 PM |
| Humble Hifi | uli | Multi-Way | 2 | 25th June 2004 02:51 PM |
| Humble Aleph-X from the Netherlands | Taco | Pass Labs | 13 | 23rd January 2004 01:25 PM |
| My humble A30 | Dennis Hui | Pass Labs | 16 | 18th November 2003 09:36 AM |
| Page generated in 0.11409 seconds (78.27% PHP - 21.73% MySQL) with 11 queries |
