My new humble thread - Page 2 - diyAudio
Old 3rd August 2011, 07:52 PM   #11
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
I did notice the cross is missing the ground connection, by nature
and thought it might cause trouble, like you say
and, when reading about 'basics', I'm obviously 'forgetting' the ccs
which, like you say, makes a whole lot of difference getting good balance
thank you
google on LTP ccs, and a lot more to read
Old 3rd August 2011, 11:03 PM   #12
Originally Posted by smoking-amp View Post
The circuit in post 8 is looking better.............................With the loop gain kept just below unity though, it may bootstrap the input impedance to eliminate loading on the 1st tube stage. Might be an interesting design concept.
oh, ok, great
well, I also thought it looked better
I take it you would suggest something like 2:1 step down
Old 3rd August 2011, 11:58 PM   #13
smoking-amp's Avatar
"I take it you would suggest something like 2:1 step down"
Probably more. Lets say a 1 volt change on the output stage grid causes X mA of cathode current increase. (actually 2X for both output tubes together) Working that 2X current backward thru the xfmr from the cathodes to the load resistor for the input stage plate, this needs to produce less than 1 volt change there (and so on the output tube grids too). (or it will oscillate!)
"If you can't solve any problems, at least make them much worse, so someone else will HAVE to solve them."
Trumpelstiltskin 1882
Old 4th August 2011, 12:18 AM   #14
Probably more.
well, the good thing is that the 'step down' doesn't affect the gain, as such...right ?
and primary impedance isn't so important as usual with IT....I guess ?
Old 4th August 2011, 12:25 AM   #15
"well, the good thing is that the 'step down' doesn't affect the gain, as such...right ?"
The forward gain is affected a bit by the step-down ratio since it determines how much driver voltage change goes to the cathodes. But the driver plate to output grid voltage stays unity. So driver output transfer is (unity+step-down fraction) to the output stage. Ie, No big deal.
Old 4th August 2011, 12:59 AM   #16
great
but the cheap IT I was looking at is no good for this
so, I can only think of Lundahl, and is not so cheap
but theory is nice, and cheaper
Old 4th August 2011, 08:49 PM   #17
very good info
thank you for your support
and also a big thank you to all who just looked
cheers
Humble Statement wigginjs Multi-Way 12 19th December 2007 05:11 PM
Humble Hifi uli Multi-Way 2 25th June 2004 03:51 PM
Humble Aleph-X from the Netherlands Taco Pass Labs 13 23rd January 2004 02:25 PM
My humble A30 Dennis Hui Pass Labs 16 18th November 2003 10:36 AM
Copyright ©1999-2017 diyAudio
