diyAudio Sponsor
Old 1st August 2011, 07:43 AM   #1
ryuji is offline ryuji  United States
Default preamplifier/driver for 807
me and my friend were discussing using 5 6SN7 halfs per channel to drive my 807's but i have seen a few projects of people using single 6au6's instead. The intentions were to have aikido line stages run into another triode as driver for the 807's.
are both solutions equivalent, or is one solution vastly superior to the other?
15 6SN7's verses five 6au6's and probably two 6SN7's for my subwoofer preamp? certainly a cost difference.
Old 1st August 2011, 10:22 AM   #2
Just curious if you have a build thread for this project. Do you use this for HT or multichannel music?
Old 1st August 2011, 04:31 PM   #3
i use the output from my xonar d2x; compared to the majority of HT boxes, the d2x has better adc and preamplification
Output Signal-to-Noise Ratio (A-Weighted):
118dB for all channels dB dB
Input Signal-to-Noise Ratio (A-Weighted):
118 dB dB
Output THD+N at 1kHz:
0.0004% (-108dB)
Input THD+N at 1kHz:
0.0004% (-108dB)
Frequency Response (-3dB, 24-bit/96kHz input):
<10Hz to 46kHz (for all channels)
Frequency Response (-3dB, 24-bit/192kHz input):
Output/Input Full-Scale Voltage
2 Vrms (5.65 Vp-p)
Sample Rate Conversion Quality:
Almost lossless, high-fidelity floating-point filters, with:
-140dB THD+N (typical value for 44.1K->48KHz, 24bit)
145dB Dynamic Range (typical value for 44.1K->48KHz, 24bit)
dont have a worklog thread but i can show how it looks now:
can show the schematics too and other information if you like
Old 1st August 2011, 04:34 PM   #4
Oh, forgot to add, This amplifier is used for games/music/movies
mostly listen to metal/rock
i dont own a tv, my PC does everything for me
Old 2nd August 2011, 05:24 PM   #5
doing some looking around, apparently the 6au6's are terribly microphonic. kind of considering using 6V6's instead. could use similar design architecture to what im using now, just adjusted for higher idle current. the -20v bias line on the 6v6 looks damn linear as long as your past 200v plate.
aikidos and more 6SN7's for drivers would require about half a ampere of b+ power in addition to collectively per channel consuming two times as much heater current as the 6v6, im thinking i'd need no more then 180 mA b+ current with this solution.
anyone have circuit/experience with using a 6v6 as a driver i can look at?
Old 2nd August 2011, 07:49 PM   #6
maybe try using a pentode like ef86/el84?
Old 2nd August 2011, 08:10 PM   #7
Miles Prower's Avatar
This is absurd. The 807 isn't that tough of a load. I used one section of a 6SN7 as a cathode follower to drive PP 807s (attached). Even if you intended to operate 'em in Class AB2, a source follower could get the job done easily. Even in Class AB2, it isn't a hard load.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 2nd August 2011, 08:36 PM   #8
the number of half's was because i was putting together a preamp and then a driver, but i guess your saying that a single half can possibly handle 1~2v rms line input just fine? when i tried running my current 12at7's just by themselves it wasnt quite enough amplification
im kind of interested in pentode driver, the 6au6 looks great on paper but i have had multiple friends/people tell me that they can/tend to be so microphonic that you can blow on them at hear it
guess i should have said that my design considerations include preamp.
Old 3rd August 2011, 07:26 AM   #9
Steve Cresswell's Avatar
I've used several brands of 6AU6 but have never experienced microphonic behavior with any of them. I'm currently using Sylvanias from 1976 with no issues.
Steve
Old 3rd August 2011, 06:35 PM   #10
This can be true of any VT. Some vintage 6SN7s are just about that bad. I've seen 6BQ7s (dual triode) that ring like bells. You can find samples that are nastily microphonic, and samples that are not.
www.dolphin-hsl.com
MC3500 with 807 tubes and modern driver tubes tryonziess Tubes / Valves 11 23rd February 2011 07:01 PM
G-807=807 SE or PP? gabrielbecheanu Tubes / Valves 8 18th July 2010 11:57 PM
6U7-G as driver in a RH 807? aardvarkash10 Tubes / Valves 4 23rd September 2009 08:12 AM
807 monoblocks sarrisk Tubes / Valves 13 28th August 2008 08:04 PM
807 Amp s2kov Tubes / Valves 5 19th January 2005 12:32 PM
Page generated in 0.11919 seconds (81.78% PHP - 18.22% MySQL) with 11 queries
