| diyAudio Sponsor | ||
I'm building phono amp. I want to use 6922 tubes in second stage and the tubes I have are made in Japan by National Elecric. On box says:
157-0125-00 date is 7/87 Does anybody know if those are a 6922 type tubes and if not what they are? |
#2 |
Lack of visual input error 4562.
#3 |
I don't know what You mean by visual input error 4562. I'm kind of new here. I need to add that tube has shield between sections.
#4 |
I think he means post a picture of the tubes in question. As number 5 would say. "More input".
mike - www.keepingsundayspecial.org |
#5 | |
#6 |
What is the pinout of the tube?
If it is the same as the 6922, it may be a 6DJ8 or a 6922. The 6DJ8 tends to have more noise than the 6922. It may work okay in the second stage.
Frank |
#7 |
As far as I can tell by looking at the tube the pin #1 & 6 are anodes and #9 is internal shield. So it may be 6922 or 6DJ8. Part number 157-0125-00 may be Tektronix part number, I don't know for sure, and they used 6922 and 6DJ8 tubes in their scopes. If my tubes are industrial versions, I wander how good are they for audio applications.
#8 |
According to that Tubes inconnus,,,besoin d'aide - Général Haute-Fidélité and knowledge of french language from school (It was living hell
), these tubes really seem to be authentic 6DJ8/6922/ECC88. Your picture supports that opinion, too. They were rebranded by National (=Richardson) for a very special purpose. Where did you got them ?
#9 |
Something very strange is going on here.
The 5960... number below the bar code is a National Stock Number Starting with 5960 it indicates an electronic tube (Surprise! The number is normally viewed in this format: 5960-00-131-1218 Checking it out it certainly references to Tektronix and to one of their partno's: 157-0125-00 Just one glitch: That appears to be a Cathode Ray Tube FYI the NSN x-ref's to an older number: 5960-00-245-6551 but that's not likely to do you much good. rgds, /tri-comp |
#10 | |
| How Can I connect A Balanced RIAA Phono Pre-Amp to a Phono Plug amp input | jmartinbaugh | Analogue Source | 3 | 25th April 2011 01:24 PM |
| rjm 6dj8 phono section | fergs1 | Tubes / Valves | 26 | 28th August 2010 02:38 AM |
| RJM 6DJ8 passive phono challenge! Pimp my board... | rjm | Analogue Source | 5 | 24th March 2010 06:41 AM |
| 6DJ8 Tube Phono and Line Preamp | Inrush | Tubes / Valves | 4 | 12th November 2009 09:04 AM |
| Page generated in 0.09968 seconds (77.92% PHP - 22.08% MySQL) with 11 queries |
