| diyAudio Sponsor | ||
Well, I took a closer look at the power supply ..yesterday:
View image: r102 amp supply Could it be that easy to boost the HT to 320v, just removing R1? I want to get more power out of the two EL84 tubes. not sure if I have to adjust R14 accordingly. The screen grids are just connected to the ouput transformer |
#2 |
Btw, calculating by turns ratio, the transformer gives 256 volts secondary.
don't know how to calculate how much the diode bridge "elevates" that. The primary winding consists of the following loops in series: 1. 114 turns 0,57 mm 2. 308 turns 0,41 mm 3. 308 turns 0,41 mm If I exclude winding 1 (114 turns) I would get 304 volts secondary Is that advisable at 220 volts primary voltage? I Know I have to look at some charts, if 0,41 mm is capable of withstanding the current. |
#3 |
The primary purpose of R1 is smoothing, so removing it is likely to introduce buzz. You could try reducing it. Alternatively, use EL86 which are intended for a lower HT voltage than EL84.
| Boost converter | Sponkii | Power Supplies | 26 | 3rd July 2009 02:05 PM |
| to boost or not to boost? | CharlieM | Subwoofers | 1 | 31st January 2009 06:17 PM |
| [enquiry] Treble Boost/High frequency Boost circuitry | elnino86 | Parts | 2 | 18th December 2008 12:33 PM |
| Using 2 chips to boost voltage handling | soundNERD | Chip Amps | 32 | 2nd February 2005 12:55 PM |
| boost circuit | wbradl1 | Everything Else | 2 | 26th October 2004 03:32 AM |
| Page generated in 0.07301 seconds (70.63% PHP - 29.37% MySQL) with 10 queries |
