What happened to my tube??
Old 28th July 2011, 05:48 AM   #1
Sperrino is offline Sperrino
Default What happened to my tube??
So I have an ART Pro MPA II Mic Pre, and I replaced the tubes with Sovtek 12AX7's. A couple weeks after replacing the tubes, the second channel died. Assuming it was a tube issue, I opened it back up and saw that the tube was in fact obviously dead. What could've caused it? I have a picture of the tube now, I have no idea what happened to it. The top of the tube is just this white stain looking thing.
ImageShack® - Online Photo and Video Hosting
Old 28th July 2011, 08:16 AM   #2
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Welcome to the forum, but please mind your language.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 28th July 2011, 08:22 AM   #3
Gilgy is offline Gilgy  United Kingdom
Looks very much like the vacuum has leaked out
Old 28th July 2011, 09:04 AM   #4
DigitalJunkie is offline DigitalJunkie  United States
Send a message via AIM to DigitalJunkie
^ +1
Old 28th July 2011, 09:10 AM   #5
chris661 is offline chris661  United Kingdom
chris661's Avatar
Look for a puddle of vacuum, scoop it up and see if you can funnel it back in there.
My work: www.grimshawaudio.com
Old 28th July 2011, 09:11 AM   #6
gruni is offline gruni  Germany
I would say that air leaked inside the tube as in my opinion vaccum can't flow.
but yes thats the point
Old 28th July 2011, 05:28 PM   #7
Miles Prower is offline Miles Prower  United States
Miles Prower's Avatar
The vacuum escaped. This is a problem with those mini types that don't have bases. Bad sockets with misaligned pins/too tight pins can promote hairline cracks at the base, especially with a few incidents of thermal cycling.
Bent pins can also cause this, and tube shields are notorious for this as well.
There is also the possibility of factory defect: either a hairline crack that wasn't noticed, or glass that wasn't quite annealed properly.
There are no foxes in atheistholes
www.dolphin-hsl.com
What happened to my tube??Hide this!Advertise here!
OK... what really happened? MatthewS Car Audio 0 13th November 2008 03:52 AM
What has happened??? shepperd Everything Else 0 17th November 2006 10:11 AM
What happened to... mikeks The Lounge 4 21st May 2005 12:08 PM
What happened here? sjohnso Multi-Way 3 3rd April 2003 11:04 PM
What Happened jleaman Everything Else 5 21st July 2002 01:53 AM
Copyright ©1999-2017 diyAudio
