diyAudio Sponsor
Old 27th July 2011, 03:41 AM   #1
Default 6EZ5 as drop in replacement for 6V6 tube?
Hello people!
I know that their heater current requirements are almost double that of a 6V6 tube?
But at 99 cents per tube (NOS/NIB RCA 6EZ5), it was too good a deal to walk away from?
Is there anything else I need to know, before trying them out??
Steve
Old 27th July 2011, 05:25 AM   #2
HollowState's Avatar
Originally Posted by leadbelly View Post
Oh, I know this game! The title I pick is: "Megan Fox stalking me?"
What kind of a bizarre response it that? What have you been smoking tonight?
Steve,
If your filament supply has the reserve juice, go ahead and try them. Everything else like plate/screen voltage, bias, plate resistance, transconductance & dissipation look close enough for audio. Only other difference is that it's a beam tetrode compared to a true pentode. A slight bias adjustment might be necessary for the best operating point.
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University
Old 27th July 2011, 05:57 AM   #3
Tony is offline Tony  Philippines
Tony's Avatar
Send a message via Yahoo to Tony Send a message via Skype™ to Tony
Originally Posted by KrankKall View Post
Hello people!
Steve
hi, can you pm me the store haveing this $0.99deal? thanks...
Old 27th July 2011, 12:36 PM   #4
tubelab.com's Avatar
ESRC no longer has them on their dollar list. Vacuumtubes.net has them on their $1 list but they have none in stock. Too bad because in most places including my SSE board they will replace a 6V6. Some adjustment of the bias is needed.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 27th July 2011, 02:19 PM   #5
The 99 cent 6EZ5 tubes were from an e-bay vender.
He only had a few, and I bought them all.
At THAT price, why not buy them and at least try them out?
Sorry guys!
That bias adjustment mentioned, is that because cathode current is higher than a 6V6 tube?
THANKS!!
Steve
Old 27th July 2011, 02:37 PM   #6
kevinkr's Avatar
Slightly different characteristics from the 6V6..
www.kta-hifi.net
Old 27th July 2011, 04:15 PM   #7
That bias adjustment mentioned, is that because cathode current is higher than a 6V6 tube?......Slightly different characteristics from the 6V6..
The 6EZ5 has slightly different characteristics than a 6V6, that will cause a higher cathode current if you just plug it into a 6V6 socket. The 6EZ5 was designed for TV vertical sweep and it has a bigger cathode than the 6V6.
Old 28th July 2011, 12:02 AM   #8
Well, I'm assuming that since a 6EZ5 does have a bigger cathode than a 6V6 tube.
That is should be able to handle higher cathode current because of that, correct??
And as long as the power transformer (and rectifier) is beefy enough to supply the additional current requirements, then it shouldn't be a problem?
Am I correct on this.....or am I swinging at a ball out of the strike zone??
Steve
Old 28th July 2011, 12:35 AM   #9
Tony's Avatar
^or you could work into lower voltages for the same power, makes your tube last longer......
Old 28th July 2011, 01:07 AM   #10
kevinkr's Avatar
Steve
In addition to previous comments about things to check you also need to check that the transformer can handle the increased current and audio output power linearly, and that the plate dissipation is not excessively exceeded - no glowing plate spots..
www.kta-hifi.net
Drop in replacement for NE5532? jmillerdoc Digital Line Level 38 10th April 2012 01:43 PM
op07 drop in replacement? kevvywevvywoo Parts 5 27th May 2010 08:12 PM
Drop-in replacement for LM208 zigzagflux Parts 5 28th January 2010 09:40 PM
Drop-in replacement for BB2227 bibo01 Parts 0 28th January 2010 06:05 PM
Drop-in replacement for TLC271 aarsoe Parts 1 12th June 2005 10:58 AM
Page generated in 0.10177 seconds (80.16% PHP - 19.84% MySQL) with 10 queries
