diyAudio Sponsor
Old 26th July 2011, 03:09 AM   #1
Default Reuse these sockets and tube choice question
On the mini-console that I am building for my grand daughter I am repurposing a preamp chassis from a hammond L101 for the preamp section of this project. The chassis has three 9 pin sockets and one 7 pin. I will need to replace the 7 pin with a 9 pin but I am considering just using the existing 9 pins rather than replacing with new.
This is a gift so I don't want to cut corners but as I look at the old sockets they look like pretty good quality and are tight. I wonder if I would really gain anything by putting in new ones.
I would like your thoughts on it.
Also my design uses 12AY7 for the CC gain stages and 12AU7 for the CF stages. I chose the 12AU7 simply because I have a bunch of used ones for the initial testing (will use new one for the final product) and since in this case they are not driving difficult loads. I am also considering redesigning for using either all 12AY7 or using 12AT7 for the CFs. I suppose ATs would give the best CF performance while AY gives the advantage of having no way to mix up the tubes.
Do you think it really matters much what I use for the CFs? Not concerned about price here at all.
Finally any suggestions on what to use to clean up the yellow gunk (flux) on those old sockets?
Thanks for your time.
mike - www.keepingsundayspecial.org
Old 26th July 2011, 03:14 AM   #2
dvh99 is offline dvh99  Netherlands
CH3CH2OH, dont use expensive brandy or whisky though .
Old 26th July 2011, 03:20 AM   #3
Maybe a bottle of Ripple. Sorry about the double post. Not sure how that happened.
Old 26th July 2011, 03:28 AM   #4
49 - for the 16th time
c2cthomas's Avatar
Those sockets look fine - no cracks - no sign of damage by heat or abuse - good looking contacts - should be good to go.
I use acetone for flux removal with a short bristle brush - stiff bristles.
"You can't always get what you want" K. Richards/M. Jagger *** "Next time I will know some things better" Zen Mod
Old 26th July 2011, 04:26 AM   #5
Tinkerer
acetone may be too hard on the old plastic, maybe try just water first? Rosin is water soluble.
Question on Tube Sockets jacko Tubelab 3 27th April 2011 05:36 PM
TubelabSE tube choice question huskydawg9 Tubelab 4 2nd March 2010 02:59 AM
question on old tube sockets jarthel Tubes / Valves 3 18th June 2007 10:32 PM
Tube sockets with the same pin spacing as the tube Andypairo Tubes / Valves 5 15th March 2004 01:08 AM
Page generated in 0.07987 seconds (74.86% PHP - 25.14% MySQL) with 10 queries
