| diyAudio Sponsor | ||
I want to make an audio output transformer for tube amplifier. So I want to know, how to calculate turns, impedance and watts? Is there any software for this? thanks!
#2 |
Google pat turner's website for some pretty comprehensive info
#3 |
Have a *.pdf of the Wolpert Audio Xfmr Design Manual, but it disappeared off the 'Net. I could sent a copy attached to an e-mail (too big to attach here).
#4 |
For the beginning, Wolpert's book is enough. For more advanced design, you need to calculate and check resonant frequency based on leakage inductance and capacitance (inter-turn / core-1st layer / primary-secondary). And check for permeability levels under small DC BIAS always present in PP amps.
#5 |
#6 |
Wolpert's paper:
http://www.dissident-audio.com/Trans...ign_Manual.pdf Software: http://www.dissident-audio.com/Trans...and-OPT.tar.gz Have fun ! Yves. Last edited by Yvesm; 25th July 2011 at 04:59 PM. |
#7 |
wow, transformers are fascinating animals, but highly highly complex and its not recommended for newbies to even go close to this sort of thing.
if you want to know a bit, here's some info....its much easier to buy one!! for se, primary turns is 33 times root of (impedance ) for pp its 44 x the same. use interleave of 0.6mm insulation, plastic, and layer it pspsp simple as that really. eg single ended 2500 ohms primary turns = 33 x root of 2500 = 33x 50 = 1650 turns, 5 layers prim, sec, prim, sec, prim. not sure about air gap, there is SOME info on the web. the primary turns is a simplification of the classic transformer equation, viz. B= (1.10 ^8 x volts) / 4.44 x Frequency x Area x turns. where b = ac flux, I have used 8000 here frequency = 20 hz Core area = 450 x root power out in mm squared. rearrange to get turns and it will simplify to the equation given, by a bit more maths. use core area above to find size of core. that's all you need, viz. turns size of core interleave pattern and air gap, the load is your own value and not given here. depends on the tube you are using. the primary turns value is foolproof, go here for more info. best site bar none for tx info its really pitiful the web for this sort of thing http://www.turneraudio.com.au/se-output-trans-calc.htm Last edited by lt cdr data; 26th July 2011 at 02:46 PM. |
#8 |
| Output Audio Transformer Impedance | kawasaki99 | Tubes / Valves | 63 | 15th December 2010 10:58 PM |
| Partridge audio output transformer value | bentoronto | Tubes / Valves | 6 | 15th February 2009 04:36 PM |
| Fender Output transformer as an audio amp part | zxx123 | Tubes / Valves | 6 | 18th January 2005 01:12 AM |
| Help needed with Audio Note DAC Output Transformer Hookup | s.hum | Digital Source | 0 | 31st October 2004 01:54 AM |
| Audio Note DAC Output Transformer Hookup | s.hum | Tubes / Valves | 0 | 30th October 2004 01:12 AM |
| Page generated in 0.11573 seconds (79.40% PHP - 20.60% MySQL) with 10 queries |
