Anyone used C3g to drive GM70? - Page 3 - diyAudio
Old 24th July 2011, 08:47 PM   #21
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
In that case, no.
Hmm,how do I adjust it as a VCCS then.
Old 25th July 2011, 02:43 AM   #22
Hello
Guys sorry is not the GM70 driver topic what I ask or write about.
Do someone used these capacitors ever for tube amp?
Aerovox still USA made caps, I would like to avoid to buy Chinese motor run capacitors.
Before you think I'm racist , I'm not just about the quality difference.
Aerovox Motor Run Capacitor - 660V - 12uf - New - eBay (item 110488117161 end time Aug-23-11 09:54:26 PDT)
Please let me know what do you think, or better to use electrolytic?
From these Aerovox I would need 10-12PC since I will build my amp in mono block with separate PS. Shipping cost $40 from USA to Canada.........
Also I will have sometimes next week orig NOS Telefunken D3a tubes I would like to trade two for Siemens and sell 2PC.
These tubes has the diamond logo on the bottom and matched pairs.
Greetings Gabor
Old 8th August 2011, 04:02 AM   #23
Hello guys
Any opinion about these capacitors for PS to my GM70 at 900V.
I purchased 12PC so I connect 3PC in parallel.
I only want to use them for high voltage. These are Epcos 250AC or 450DC and 150uF each. EPCOS B32361A2157J050
B32361A2157J050 EPCOS Suppression Film Capacitors
Price "an arm ad a leg"
Greetings gabor
Old 8th August 2011, 04:34 AM   #24
Ryssen's Avatar
For 900v you should connect them in series 3 peaces.
If you want more uF you then connect 3 in series wich you connect in paralell to the other 3,and if you want more...
Old 8th August 2011, 09:12 AM   #25
ratbagp is offline ratbagp  United States
If you can fit them in, these might work for you in parallel.
Surplus Center - 88 MFD 1200 VDC RUN CAPACITOR
ray
Old 8th August 2011, 01:42 PM   #26
Hello
Yes you right I'll connect them in series.That is what I thought.. Just a typo mistake..
Ratbagp
Nice capacitor for that price.
Greetings gabor
c3g connections garbage Tubes / Valves 8 16th October 2010 09:51 AM
C3g:GM70:GM70 schematic advice louischia Tubes / Valves 24 27th August 2010 05:01 PM
Anyone used C3G to drive a 2A3 before? d3aPentode Tubes / Valves 1 7th December 2009 08:24 AM
GM70/GM70 parafeed SET? louischia Tubes / Valves 10 4th December 2008 04:12 PM
C3g stecairoli Tubes / Valves 2 17th September 2006 08:02 PM
Copyright 1999-2017 diyAudio
