Dynaco Mark IV Power Resistor - Page 2 - diyAudio
Old 21st July 2011, 10:49 PM   #11
DF96 is offline DF96  England
It would have been helpful and courteous to tell us from the beginning that it was a new DIY build. Fault-finding depends partly on context, which you did not disclose. Debugging a build and fixing a previously working item are not the same thing, because different types of fault are likely to occur.
Old 22nd July 2011, 12:57 AM   #12
denny9167's Avatar
My humble apologies! I need to develop better board ethics!!
Old 22nd July 2011, 01:09 AM   #13
llwhtt is online now llwhtt  United States
DF96,
I tried telling that to someone on the PASS forum, he had built an A40 and had a bad channel, forgot the particular problem. He had one good channel to troubleshoot with but kept asking what would cause this problem. I told him troubleshooting a once working amp is totally different than something he built and NEVER worked. I don't think he cared for that, never saw him again on the forum.
Craig
Old 22nd July 2011, 08:21 PM   #14
Accepted.
Old 22nd July 2011, 09:26 PM   #15
kevinkr's Avatar
Originally Posted by denny9167 View Post
I apologize folks,I was leading you astray. It was a screw-up on my part. By the way in case your wondering this is a NEW build. Theres nothing wrong with the cap,I mistakenly mis-wired the take-off socket. the wire was supposed to be soldered to pin #4 and the 22K resistor,was soldered to pin #3 by mistake,which would take the current through the 10ohm resistor straight to ground.
Oops, yep that will do it.. Good catch..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 22nd July 2011, 09:35 PM   #16
denny9167's Avatar
You have that right!!! If I only double checked my work I would have discovered it,and this post wouldn't have been nessessary. All is good now. This jewel of an amp seems to be working the way it was designed to do,my hats off to Mr. Hafler,and Mr. Laurent for designing some great products!
Old 22nd July 2011, 09:55 PM   #17
denny9167's Avatar
Here are some picks,biasing nicely!
converting a dynaco mark IV driver board for headphone amp use speakerfritz Tubes / Valves 0 27th November 2010 08:51 PM
Dynaco MK IV Mystery eric0108 Tubes / Valves 13 6th December 2008 12:10 AM
Dynaco MK IV gofar99 Tubes / Valves 2 9th February 2008 02:28 PM
Dynaco Mk IV question audioquestM-40 Tubes / Valves 6 21st December 2005 06:00 PM
Any heard of Mark IV Electronics? Ionstorm Parts 7 3rd January 2004 07:46 AM
Copyright 1999-2017 diyAudio
