diyAudio Sponsor
Old 20th July 2011, 07:48 AM   #1
Default Looking for analog Tube schematic for "analogmetric 1541a" DAC
Hello,
I have DAC from analog metric using TDA1541a.
And I want to change the analog output with tube, disable the opamp on board.
Now it's using Opamp onboard which I don't like the sound.
Does anyone done the analog part using tube like 6DJ8 Or bigger tube like 45 ?
any schematic. Will be appriciate.
Cheers
Cal
be tube
Old 21st July 2011, 12:53 PM   #2
Zibi is offline Zibi  Poland
6DJ8 output for TDA1541a DAC - Google Search
Old 22nd July 2011, 02:31 PM   #3
any tube buffer will do the job
Old 2nd March 2012, 07:13 AM   #4
Mayday is offline Mayday  Sweden
Found this thread when I did a search.
I'm building a TDA1541A Dac, using the analog metric pcb but I have very carefully selected the parts myself.
Anyway, I'll listen to it for a while when done before putting in passiv I/V and ECC86 output.
Build thread
/Jonas
The more you learn, the more you realize how little you know...
Mayday DIY blogg
"Adagio" style Tube DAC slav Swap Meet 11 19th July 2011 07:28 PM
31 Band Equalizer "the t.eq" "TQ-60" schematic wanted tiefbassuebertr Solid State 2 29th March 2010 03:45 PM
Favorite Threads and Posts in "Analog Sources" Variac Analogue Source 4 25th July 2007 11:03 PM
power supply schematic with a 6080 used as a "pass tube" jarthel Tubes / Valves 1 27th May 2006 03:41 PM
Page generated in 0.07866 seconds (70.72% PHP - 29.28% MySQL) with 10 queries
