diyAudio Sponsor
Old 20th July 2011, 02:05 AM   #1
kmaier is offline kmaier  United States
kmaier's Avatar
Default 2A3 SETs with Edcor Iron
I started another side project recently, a 2A3 SET based on an old classic schematic similar to the Fi series of 45/2A3 SETs (with a slight change). I wanted to try some Edcor iron so I picked some of their current lineup and ordered it... then went for coffee.
Ah, after the iron arrived I did the mechanical layout and opted for two separate chassis; one for the power supply and one of the amplifier, so 4 chassis mirror-matched.
Here's a couple pics of the final mechanical assembly. I used one of the newer 1590DE series Hammond die-cast series... metric dimensions and black powder coat. They survived drilling to 3/8-inch and Greenlee punches to 1-1/8" without issue.... and just manage to support the 25W SE OPT from Edcor... it's a monster.
Wiring is next
Regards, KM
... just because you're paranoid, it doesn't mean they're not after you...
Old 20th July 2011, 02:44 AM   #2
Pano is offline Pano  United States
Pano's Avatar
Cool setup!
Old 20th July 2011, 09:17 PM   #3
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
+1
Old 22nd July 2011, 04:46 PM   #4
kmaier's Avatar
Default Power supply wired
Wired up one of the supplies yesterday. It works... then again, not much to it.
Regards, KM
Old 25th July 2011, 05:52 PM   #5
kmaier's Avatar
Default 3 down, one to go... but....
Have wired up the second power supply and one of the amplifier chassis. Both supplies perform as expected... the amplifier circuit (basically what the Fi SET uses) is somewhat underwhelming. Output power is light (barely 3 watts before clipping), THD is pretty high and frequency response is down a few dB at 20KHz. The default biasing on the 6SF5 input/driver is ~ 0.45ma which is pretty low. I'll re-bias the amp a bit and see if I can get an acceptable level of performance but there will be limits.
Regards, KM
Iron ste for 2A3/300B Jozef Swap Meet 0 14th June 2009 10:44 AM
FS: Edcor iron package for SimpleSE and related amps jrebman Swap Meet 0 17th March 2008 06:28 AM
Tri-amp using 2a3 SETs marcutan Tubes / Valves 13 2nd March 2008 10:49 AM
WTB: OPTs for 2A3 or 45 SE; 240 v power tranny for 2A3 or 45 rick57 Swap Meet 0 8th November 2006 01:07 AM
Iron set for Paraglow (2A3) SET amplifier Alain Favret Swap Meet 1 19th March 2004 06:23 AM
Page generated in 0.08190 seconds (74.93% PHP - 25.07% MySQL) with 11 queries
