tube B 406 triode dick's cleo 4
Old 31st August 2011, 07:45 AM   #11
suwaned is offline suwaned
suwaned's Avatar
Default the Manta
hello Manta ,
sorry, long time, I did not contact you.
I wanted to let you, that I've assembled preamp.
follow your advice, first from a given scheme, with a 0.47 uF C output.
have been tried to be heard.
your right, her voice a little amplification if I try to, amps 10Y
but when tested with a parallel push-pull, VTL MB125, gained considerable amplification.
problem: low buzzing tone and noise. --- Little ---- (equal to 1 step attuenator) I do not know how many DB.
Sound is heard: Sound is quite flat and wide enough, but the sound is muffled, (than I have yet to change the Power supply from 10 H to 20H --- I think it can help to eliminate noise and low buzzing tone)
But I am very happy, have tried to assemble my first preamp. this because of your help, thank you once again.
I will still try to get better results. because yesterday I tried to test without using the line out put ransformator sound more open than ever before with the line OT.
thank you MANTA for you help.
Old 31st August 2011, 08:37 AM   #12
suwaned's Avatar
problem: noise and low buzzing tone.
the placement of the transformer may be inflicted on the box?
please corrections for correct placement
thanks
(pic placement)
Old 20th December 2012, 04:35 PM   #13
suwaned's Avatar
revision
Old 2nd January 2013, 05:04 AM   #14
suwaned's Avatar
Default wiring
using 2 layers
top with aluminum plate, which is painted black glossy shine
the second layer to hold base the part.
there are no screws on the top surface.
wiring partialy done under layer.
used line output hashimoto HL 10k-600
schematic follow the advise from Manta
the first schematic
Old 2nd January 2013, 09:50 AM   #15
sandyashari is offline sandyashari
I really enjoy just watching the picture.
very neat...... esp the 1st pic.
Old 2nd January 2013, 01:46 PM   #16
tyo94 is offline tyo94  Indonesia
Send a message via Yahoo to tyo94
Nice appearance for long awaiting preamp.... Just can't wait to hear this one sing
Conrgats ko...akhirnya!
Old 4th January 2013, 04:41 AM   #17
suwaned's Avatar
Thank you, for your support my friends.
I have another B406 preamp.made that as third diagram of Manta but not used line OT (used R-C=0,45uf)
Rect: AZ1 VAlvo ,
C1 (powersupply) 20uf Jansen Cap Metallized.
if friends have experience with this cap. please share.
http://www.youtube.com/watch?v=exlv_-okKyg]TANNOY canterbury with tube B406 + 26 + 45 + 300B - YouTube[/url]
Old 4th January 2013, 02:39 PM   #18
Bas Horneman is offline Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Basically you have to shield the tubes. Those old triodes are very sensitive to anything around them. Try a placing a piece of metal between the transformers and the tube. Something like a can with top and bottom removed.
If you can see the speaker cone move...it's not hifi.
Old 4th January 2013, 11:45 PM   #19
suwaned's Avatar
hi Bas
my the simple preamp with gnd cahthode B406. I done like you opinion. my tube far from iron.
at the beginning I made, obtained hum problem but it can be fixed by replacing the resistor of filament 56R with TDO-VD25 Enclosed Wire Wound Variable Resistor 25W,
I use dc filament supply of PCB Bellaaudio Lt1804 regulator.
maybe I got lucky .... sorry I do not have basic that theory. my capital just try and error.
my experience with a microphonic tube (high-pitched hum or echo), turn on the filament without high voltage during what hours. it is enough to help.
if hum (low pitch - buzz...) it is influenced filament supply.
it can be used for the filament supply DHT from COLEMAN. This is great and very good for the dc filament supply. I've tried on my power, 26-45-300B (follow HQ-DHT from Quanghao). hum goes away.
Old 6th January 2013, 03:40 PM   #20
suwaned's Avatar
tyo come see this.............................
me and friends - YouTube
tube B 406 triode dick's cleo 4Hide this!Advertise here!
UXCV11 Triode Tube tubeman Tubes / Valves 8 17th June 2013 10:37 PM
Cleo: End to End 24bit 192khz USB DAC with tube output bcherry DIY HiFi Supply 7 3rd July 2010 11:15 PM
24A tube in triode mode, help !!! aldovan Tubes / Valves 6 18th May 2010 10:36 AM
Help on 311-CH triode tube georgehifi Tubes / Valves 1 30th April 2004 12:55 PM
Copyright ©1999-2017 diyAudio
