diyAudio Sponsor
Old 17th July 2011, 05:05 PM   #1
Smile GE Snubber, High Current DC, and Switching Capacitors
Hello,
Has anyone used GE Snubber, High Current DC, and Switching Capacitors as coupling capacitors or anything audio? How did they work?
I have a crate full of GE capacitors 0.15uf, 0.33uf, 0.68uf and 5.0uf. I have a 0.33uf model number 42L1332 in my hand?
Thoughts?
Thanks DT
Old 17th July 2011, 05:13 PM   #2
indianajo's Avatar
I've used 50 uf 440 VAC (1000 vDC) Genilec film capacitors as B+ main capacitors after the tube rectifier in a tube organ. Replace dried up 40 year old electrolytic cans. Work fine but are so huge I had to put them in a separate chassis. Ran the current up and back in twinax radio cable, shield grounded at only one end to chassis. Plus went up and back in one cable, negative went up and back in another cable. Used .25" flag terminals on capacitor and screw strip on power chassis.
GE also made electrolytic capacitors, make sure these don't have a plus on one end and aren't over 15 years old.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,SP2-XT's, T-300 HF Projs, Steinway console, Herald RA88a mixer, Wurlitzer 4500
Old 17th July 2011, 05:23 PM   #3
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Looks like they are 42L series Metalized Polypropylene, so they should be good caps.
Those values are more likely to be good for bypass caps as big as they are.
The lower values might be good for coupling caps driving big tubes with high drive requirements.
Good find!
GE Capacitors? SQLGuy Solid State 3 20th January 2009 10:07 AM
High Current relays for speaker switching? Zero Cool Everything Else 13 15th December 2006 11:52 PM
High current DC power supply nikogian Solid State 1 26th March 2004 08:03 PM
Choke-Input: How do I calculate the right snubber for high-current-low-voltage Blitz Solid State 20 24th March 2004 08:37 PM
High current DC power Supplies fr0st Parts 7 27th April 2003 03:28 AM
Page generated in 0.08271 seconds (63.85% PHP - 36.15% MySQL) with 10 queries
