diyAudio Sponsor
Old 17th July 2011, 06:33 AM   #1
Default Back From the Dead- A NOS Tube Story
Before you throw that 'bad' tube away, read this.....
A couple of days ago a sleeve of NOS RCA 12AT7s arrived in the mail. Yesterday I pulled out the tester (Eico667) and tested a bunch, including the NOS ones.
I was surprised to find that one of the NOS RCAs tested 55/74. (On the 667,<60=fail, 60-80=??).
This morning I was talking to John Albion (PacificTV-well known tube dealer) and asked him if this (NOS testing bad) happened very often.
Answer:"Sure"
Then he continued, telling me to put the bad tube to work for a few hours and test it again..that often the tube will come up to spec.
Back home, I put it in the RH84 amp, played a CD, and tested again. Result: 80/88
Back into the RH84 for another couple of hours....120/100.
Obviously this won't work for shorted tubes- you don't want them in your amp - but for low emission, it's worth a shot, IMO.
Old 17th July 2011, 11:50 AM   #2
SY's Avatar
Sometimes, this can work by re-activating the getter.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 18th July 2011, 11:25 AM   #3
DF96 is offline DF96  England
Surely reactivating the getter will reduce positive grid current by mopping up gas but won't increase emission? More likely that the cathode was reactivated, although how it got deactivated in an unused valve is unclear.
Old 18th July 2011, 12:57 PM   #4
Any chance its the getter material itself which gets driven off the filament ?
-Antonio
Old 18th July 2011, 01:03 PM   #5
Alastair E's Avatar
Ive had something similar....
Running the heaters at 20% over rated for about 1/2 hour normally does the trick....
This can also help with some marginal used valves as well...
Das Beste Oder Nichts
Old 18th July 2011, 01:47 PM   #6
When an oxide cathode is first made it has poor emission. At the factory, after the vacuum is put in, the heater is run at well above its normal power for a period (minutes, hours?) to activate the cathode. This does something to the surface (metal ions migrate to there?) which makes it emissive.
Sometimes an apparently worn-out cathode can be reactivated. I'm not sure why an unused valve would need reactivating, though.
Getters often work better at higher temperatures. Some only work at high temperatures, although these are generally only used in high power valves. Reducing gas is unlikely to improve emission, although it may reduce the rate of decline in emission by protecting the cathode from positive ion bombardment. Less gas should mean less positive grid current.
Old 18th July 2011, 01:50 PM   #7
Pano is offline Pano  United States
Pano's Avatar
Originally Posted by DF96 View Post
...after the vacuum is put in...
That's an interesting way to phrase it.
Old 18th July 2011, 01:56 PM   #8
I bet you are a blue-smoke denier!!
JL audio 8w6 brought back from dead? bluetjjason Car Audio 3 24th April 2011 01:46 AM
What kind of tube did I use back then? sprinter Tubes / Valves 19 6th March 2011 07:23 AM
Blue glow in tube. Is the tube dead or not? Pentium100 Tubes / Valves 37 22nd October 2009 06:45 PM
Do tube curves tell most of the story? bigwill Tubes / Valves 8 18th November 2007 05:54 PM
My Tragic story about Emission Labs tube Michaellu5250 Tubes / Valves 2 31st May 2005 01:04 PM
Page generated in 0.09644 seconds (72.83% PHP - 27.17% MySQL) with 10 queries
