diyAudio Sponsor
Old 16th July 2011, 08:46 PM   #1
Jaap is offline Jaap  Netherlands
Jaap's Avatar
Default application for ccs/gyrator board from the groupbuy
Anybody a suggestion for how to use this board for a 76 tube ?
see schematic
Old 17th July 2011, 05:14 PM   #2
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
I´m Interessted in this myself,but your picture doesnt expand so I´m making a link.
PCB for cascoded IXYS CCS (tube)
Old 18th July 2011, 12:59 PM   #3
Alastair E's Avatar
Seems terribly complicated.....
Is there any advantage over a more simpler design?
Das Beste Oder Nichts
Old 18th July 2011, 02:25 PM   #4
Michael Koster's Avatar
The circuit is a simple two device cascode. There are two of them on the board plus optional bias regulators for constant voltage "gyrator" operation. Reading through the thread will clarify the purpose of the various options.
This application of this board for a 76 tube depends on what you want to accomplish. Let's say you want to use the 76 as a single stage line amplifier with a gain of about 14x.
The 76 has a relatively high plate resistance, and one wants low output impedance from a line amp, so I would use the circuit as an anode load with the mu output.
For a single stage amp using a low gm triode, either CCS or gyrator would be appropriate. One might try both to see if there is a difference in sound or stability.
parafeed - Gyrator vs CCS anode load adamus Tubes / Valves 51 28th August 2011 11:47 AM
Off board MOSFET's & CCS voltage regulator zebra100 Solid State 6 21st July 2010 01:27 AM
Rod Coleman CCS/gyrator help zigzagflux Tubes / Valves 14 6th March 2010 11:40 PM
CCS Conceptual Qs, Using Gary Pimm CCS as Example DrDeville Tubes / Valves 20 12th May 2004 02:41 PM
Page generated in 0.07493 seconds (72.19% PHP - 27.81% MySQL) with 11 queries
