Building a tube radio
Old 13th July 2012, 03:53 PM   #11
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
I've made some regens for AM reception, and audio quality is pretty fine IF PROPERLY OPERATED. It takes a few time to get the received adjusted, but when you get familiarized, it works very good.
But, for a good regen, you need the lower mu triode you can get, and the lower +B compatible with the audio output, so a little of practice, you will get a good compromise. Remark that lower mu is important, medium or high mu triodes or pentodes make exact regeneration point difficult to find.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 13th July 2012, 04:43 PM   #12
DF96 is offline DF96  England
Be careful of superregens, unless you have no near neighbours. Even with an RF amp they can still radiate mush. They are also not known for low-distortion audio, as they have an exponential response.
Those with no previous radio experience could start with a regen (not superregen), perhaps combined with reflex. Then try a simple AM superhet. Leave VHF FM until last, unless you enjoy disappointment. RF is harder to get right than audio, because all the parasitic components which never appear in the circuit diagram have a habit of biting you when you are not looking!
Old 13th July 2012, 05:09 PM   #13
Cassiel is offline Cassiel  Libya
Originally Posted by kevinkr View Post
Very cool FM super regen, think I might want to build something based on this design..
I did but couldn't make it work without some annoying noise. Of course you know a lot more than I do so don't give up just yet.
Old 13th July 2012, 07:55 PM   #14
Superregens always make a lot of noise between stations. They aren't exactly quiet when on a station, either. Only use when you need to the best you can with one device (or perhaps two) or cheapness is the only criterion.
Old 13th July 2012, 08:09 PM   #15
Boy, don't care. Im manipulating RF since 1985 when I was 15, when I made my own 6DQ6 AM 30W emitter, and the receiver. The TX has the power trafo and modulator choke winding of my own in an old manual drill used as a winding machine, and counting turns manually.
Regens receivers, when properly constructed and adjusted DO HAS BETTER AUDIO QUALITY because YOU fix at any moment RF bandwidth and haven't converter, IF and detector distortions. As a regen fan, I can sure this fact. And, there is a difference in supper-regens, and regens. Regens doesn't need to oscillate, but in some circumstances, is need it does it (For example, when receiving CW or SSB). Super regens always oscillate, and the quenching oscillation is capable of cause QRM to other receivers.
Old 13th July 2012, 08:48 PM   #16
Regens suffer from the problem that gain and bandwidth are linked via the regeneration control. In Europe at night it is quite likely that the next audible station is only 9kHz away. The leaky grid detector can be something of a compromise, although no worse than many diode detectors. No AGC to counteract night fading. A superhet can provide better audio, although most do not because of too narrow IF bandwidth and diode detector loading.
Old 13th July 2012, 09:30 PM   #17
Miles Prower is offline Miles Prower  United States
Miles Prower's Avatar
They don't have to. The design goal is usually communications effectiveness, not fidelity. For SSB, fidelity is impossible, and for AM, not legal, as the BW is quite limited, even for commercial. BCB AM. Thus, the "too narrow" IF filters -- too narrow for fidelity, but not for what they were designed for.
You have to watch out for that in audio design as well. Especially when using pents or cascodes. Don't keep the strays under control, and it'll probably oscillate.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 16th July 2012, 01:12 PM   #18
For those interested in Regens, there is a forum regenrx at yahoo groups. Im registered there. Yesterday I was testing my RegenFET and found an interesting device called 2SK427 that has a curves family much similar to triodes, and as a regen works very fine. I did a cascode previous to it with a 2SK117 (down) and 2SK246 (Upper) and get about 400mV at the audio output from a ferrite antenna coli. This is the receiver for my RegenFET (an all-FET no BJT no IC) MW regenerative portable AM receiver. Briefly I post a schematic for those who want to play with it.
Building a tube radioHide this!Advertise here!
How to boost FM radio signal inside a steel building SharpyWarpy Everything Else 16 9th February 2011 05:50 AM
Help - tube radio JDeV Tubes / Valves 49 19th October 2006 09:18 PM
Tube Radio Kit cuallito Tubes / Valves 11 29th May 2004 11:59 AM
Old russian tube radio janar74 Tubes / Valves 17 2nd June 2003 02:52 PM
Another tube radio Magnetmaz Tubes / Valves 7 11th March 2003 07:01 PM
