diyAudio Sponsor
Old 15th July 2011, 10:30 PM   #1
kegger is offline kegger  United States
Default Large power push pull output transformers, say 150W
If you were in the market for some 150w push pull outputs for multiple pairs of EL34/KT88
(this amp uses 8 EL34 per channel at relatively low voltage and current in UL at 140w)
What would be some of the choices you might suggest?
(any and all comments welcome)
Thanks,
Keg
This is new territory for me, so I'd be guessing..
Old 15th July 2011, 11:01 PM   #2
Depending on the power bandwidth you are working with, the 120 watt Hammond transformer will work, although would likely require fixed bias to reach your power goal. For say guitar amp frequency needs, that transformer should be able to handle 140 watts rather easily. From an ideal design standpoint I would rather like to see the primary impedance around 1500 ohms for a quad push-pull setup, as that would be a little easier on the screens. In any event, it's best to work on big suckers like this though in the winter time!!
Dave
Old 15th July 2011, 11:15 PM   #3
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Unfortunately, big suckers would require high primary impedance that impacts on higher frequencies. Many small suckers in parallel are better, in terms of output transformer cost.
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 15th July 2011, 11:21 PM   #4
Thanks guy's, this is fixed bias.. (and HIFI use)
I have no specs of the output transformers in there, 1 is bad so I'm seeking alternatives.
Old 16th July 2011, 02:08 AM   #5
Can you measure the good one to at least get an idea of the turns ratio so the impedance can be calculated? For hifi use, the 280 watt Hammond unit would surely deliver the low end goods, but the high end performance would certainly be compromised. For that matter, I believe that virtually any transformer with an adequate core that can handle the lowest octave of the audio spectrum, with low distortion, that is rated for more than 100 watts, will have some degree of compromised HF performance -- although in this case, keeping the primary impedance low certainly helps in that regard.
Dave
Old 16th July 2011, 02:13 AM   #6
SY's Avatar
I'd look for something in the 1.2-1.5k:VC range. That's a decently low turns ratio and will match well to 4 pairs of EL34.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 16th July 2011, 06:33 AM   #7
richwalters's Avatar
Remember parallel p-p with Z halved needs fewer turns, hence lower leakage parasitics but a larger core for lower throughput power.
A well designed full b/w E&I o/p tranny should have an upper f cutoff
around -3dB 70Khz and for 150W, down to 20Hz expect a 21 Lbs weight.There are design advantages; copper wire OD can be increased without serious penalties further lowering the already low DC resistance. High DC primary resistance leads to higher THD.
I use 2K A-A....with 4xKT90 at 600V B+; easy 200W+.
If one is using a stereo or twin as I do and bridge o/ps, the power supply is going to need alot of attention.
richy
Old 16th July 2011, 07:00 AM   #8
Wavebourn's Avatar
Richy, I was responding about big sucker tubes. Indeed, paralleled tubes on lower B+ are more OT - friendly.
Old 16th July 2011, 07:30 AM   #9
Thanks guy's..
Rich(Richy).. If I may ask, what output transformers are you using?
As that was more my inquiry, I figured between 1.2-2.2k primary would
be where I'm looking but I was curious who makes a decent one or was
there 1 others have used with good success or thought was to be nice.
I can't get to the one in the amp as of yet(bunch of stuff to take apart)
It is a pair of mono blocks, running only 390v B+, and pretty low current.
(an yes I'd be looking to replace as a pair, weighing options as of now)
Appreciate all the info given, Thanks..
Old 16th July 2011, 09:35 AM   #10
hidnplayr's Avatar
You can measure the primary impedance while it's still inside the amp, just be very carefull
You'll need an o'scope with 2 probes, a dummy load and a signal generator..
Real tubes have top-caps
Commercial Audio Brands: N-Ch/NPN only output devices in a push pull power follower tiefbassuebertr Solid State 0 11th May 2011 10:15 AM
Transformers for Push-Pull sweep tubes rsumperl Tubes / Valves 19 4th April 2010 11:50 AM
Difference between SE output transformer and push-pull output transformers hilbert_mostert Tubes / Valves 12 8th March 2009 05:10 PM
Output Transformers for an EL84 Push-Pull Amp boneshaker Tubes / Valves 2 3rd August 2006 07:52 PM
current mode push-pull smps, how to design sense transformers? zilog Power Supplies 21 3rd March 2006 03:32 AM
Page generated in 0.10372 seconds (78.50% PHP - 21.50% MySQL) with 11 queries
