| diyAudio Sponsor | ||
I need a schematic for a monster amp project
what I have to work with: 4 x 200w OPT (NOS) 2 x Chokes (NOS) 2 x UTC S-43 PT (NOS) I also have anything else I need to complete this project. As for tubes? I am open to any suggestions? I do have access to most any tubes needed. no mater how rare. I am looking for like 125w per OPT for a set of 250w mono's and a stereo amp at 250w. Or if I can find the right plan I would go 2 x 250w mono's It all depends on the schematic. Thanks WO |
#2 | |
![]() choke> current? What about 4x gu50 pp class AB much power low cost.
( (( KUGELWELLE )) ) recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet Last edited by Helmuth; 15th July 2011 at 04:24 PM. |
#3 |
This is a fun website for schematics: Audio Tube Amp Schematics
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,SP2-XT's, T-300 HF Projs, Steinway console, Herald RA88a mixer, Wurlitzer 4500 |
#4 |
More details about OPT are needed, to suggest something real.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#5 | |
What speakers are you planning to use? You are going to have to measure and characterize that OPT. At the very least figure out the turns ratios. I assume a 200W OPT is for a push-pull amp. Are there ultalinear taps? |
#6 |
www.kta-hifi.net |
#7 |
#8 | |
This thread's OP already has the Iron. His power transformers are more modest and I doubt can do more than 100W. Best I could find is these are Chinese made (by UTC) 400 volt transformers but they don't spec the current from the 400V secondary but he has about 5A of 6.3 to work with or maybe 4A as running at the limit s not good. So I think perhaps he could run a "quad" of 6L6, or KT66 tubes in each of two mono amps. Last edited by ChrisA; 15th July 2011 at 10:02 PM. |
#9 |
Hi Guy's,
I have been collecting parts and working on the chassises for the Mono's. Sorry about the delay in coming forth with answers. OK The OPT are 5000K and will be going PPP The power tyrannies are 525-0-525 450Ma 40-0-40 200Ma 6.3v@5A 5v@3A 5v@6A 6.3v@2A Still on the fence on what tubes to use for 125w for EA mono. And I am going to build seperate power chassies as the weight will be to much with everything on one board. Anything else you need for info? And thank you for your time. WO |
#10 | |
The UTC OP are made in NY and are vintage NOS, They are UTC S-43 high output. Go search the specs? These are just the right size WO Last edited by WildOne; 31st August 2011 at 04:24 PM. |
| Any information and schematic about diy Pass Lab XA 200 power amp and X 0.2 pre amp? | jelou | Pass Labs | 17 | 4th December 2011 10:56 PM |
| 200-300 W class D amplifier? schematic? project? | DigiSoft | Class D | 27 | 20th March 2010 08:11 PM |
| Best HighEnd USB DAC schematic/DYI project.. which one? | mandrei83 | Digital Line Level | 0 | 18th June 2009 03:51 AM |
| Project 27- quick schematic question | DeadSpeaker | Solid State | 4 | 6th April 2008 06:17 AM |
| TOPWARD MODEL 605 operation manual & Schematic | ku5355 | Tubes / Valves | 0 | 16th December 2005 09:40 AM |
| Page generated in 0.09851 seconds (87.24% PHP - 12.76% MySQL) with 11 queries |
