| diyAudio Sponsor | ||
Hi
I’m upgrading a pair of 300BSE amps for a friend. I’d like to upgrade the four solid state rectifier diodes, arranged in a bridge, in each power supply. At the moment it has un-bypassed small glass pacified types fitted- will have to remove one to read label, but they may be a suitable avalanche type, as the amp was commercially serviced a few years ago. Not 1N4007 at least! The transformer tap is 400 – 0 V ac, and the supply, after smoothing, outputs about 480 V @ ~ 125 mA. There's only room for RC filtering of the raw supply, so no subsequent chokes I'm afraid. My own gear uses exclusively indirectly heated valve rectified, choke input supplies, so I’ve not kept up to date with the latest developments. The only solid state rectifiers I use on my valve gear are cap bypassed BYV32E soft recovery types in the filament supplies of the 300Bs (though I’ve used 1N5822 Schottkys in the present amp). Where is the smart money these days? Si-C schottkys or fast recovery type? Cap bypass or not? Or what? Thanks Paul Last edited by needsp; 15th July 2011 at 01:27 PM. |
#2 |
Why change the diodes?
Is there low level buzz caused by poor reverse recovery? If so just add a fast recovery between the bridge and the first cap. No need to replace them. |
| Solid State Regulator for tube amp | NBBN_amplifiers | Tubes / Valves | 49 | 17th August 2010 06:27 PM |
| tube solid state hybrid guitar amp, looking for schematic | jmillerdoc | Tubes / Valves | 17 | 10th February 2010 06:24 AM |
| Solid State power amp supply | pjpoes | Power Supplies | 1 | 19th March 2007 04:18 AM |
| Power Supply Design Strategy--Solid State for Tube Amp, From Morgan Jones | DrDeville | Power Supplies | 0 | 14th December 2006 09:18 PM |
| Rectifiers: Tube vs Solid state.. | cathode_leak | Tubes / Valves | 26 | 13th May 2005 12:45 AM |
| Page generated in 0.07941 seconds (69.68% PHP - 30.32% MySQL) with 10 queries |
