| diyAudio Sponsor | ||
I feel like I should preface this post with long time listener first time caller or something like that. I'm not completely sure if I am posting this in the correct place but hopefully the mods will steer me to the right place if I am wrong.
I am in the process of planning out a a nixie clock, vacuum tube AM/FM radio. I have everything planned out for the clock portion and a few ideas for the radio but since the only tube radio I ever attempted was a single valve crystal radio that I built with my dad for a project in middle school many years ago, I am looking for some good sources for info and design ideas. I recently acquired a copy of the radiotron designer's handbook 4th ed. which has been quite helpful so far but I was hoping to get some additional info/schematics of projects people have attemped for Superhet AM/FM receivers. |
#2 |
Best to learn with a TRF radio, then try an AM superhet. To get any further you will need test equipment and experience. Don't try to start with an AM/FM set as you are almost certain to be disappointed. To be blunt, most audio people would struggle to correctly adjust an already-built FM set so building from scratch is harder.
I am not trying to put you off, just alerting you to the fact that you have started on a long and interesting journey. RF is harder than audio. VHF is harder than RF. |
#3 |
Yeah, I fix amps, organs, preamps, mixers, but I can't get any sensitivity out of my dyna FM3 tuner yet. The schematics and alignment instructions are free now after 45 years, downloaded them last spring. Might work up to trying replacing electrolytic caps and aligning it next winter. I re-capped a buzzy hizzy, poor sensitivity 5 band (1979?) transistor radio last year, sounds great, super sensitivity on FM band. Only a mono radio, though, next act, stereo! (?)
To ease into radio, try repairing an old radio found at a charity resale shop. After that, buy some old Sams schematics or something, try to dupe the good ideas off one of those. Hard to buy the inductors and variable caps these days, easier to find them in old junk.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,SP2-XT's, T-300 HF Projs, Steinway console, Herald RA88a mixer, Wurlitzer 4500 Last edited by indianajo; 14th July 2011 at 05:41 PM. |
#4 | |
#5 |
OK, in your case the journey may be quicker! Much of what you already know will be directly applicable. Something which might catch you out is that stage gain for valve RF circuits is much greater than solid state, so stability can be an issue. Also, impedances are higher so stray capacitance tends to be a bigger problem than stray inductance.
I suppose what I am trying to say is that the theory you know is still true, but your experience could sometimes mislead you because valves are different. |
#6 |
You can find cheap AM/FM stereo receiver chassis cheap enough on e-pay, something from a vintage console, and modernize it using better parts than were available to original manufacturing. Anyway you will need to find at least cores for RF coils and IF transformers.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#7 |
you just hit the nail on the head for my biggest concern. Fortunately for my career, we dont have to worry about many of the same things RF designers did back then. Unfortunately for this project, I have never had to consider some of the same things I will now.
#8 | |
#9 |
mcwilcr,
There are a couple of major stumbling blocks in your path towards building tubed superhet circuitry: acquisition of tuning capacitors and acquisition of IF transformers. IIRC, a fellow in Germany makes and sells IF trafos and you may be able to use reverse connected BJT trafos in a parafeed setup. Given your EE background, you may be able to solve the problem of using varicap diodes for tuning a tubed setup. If you do, PLEASE post your results here. A simple AM project is a single tube regenerative setup. Only a readily available 365 pF. single gang tuning cap. is necessary and you get reasonable sensitivity. A "slick" single bottle (12AT7/ECC81) FM design can be found here.
Eli D. |
#10 | |
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,SP2-XT's, T-300 HF Projs, Steinway console, Herald RA88a mixer, Wurlitzer 4500 Last edited by indianajo; 14th July 2011 at 06:35 PM. |
| Vacuum tube VCO | Bitrex | Tubes / Valves | 1 | 15th March 2011 12:07 PM |
| Need help finding 50's car radio vacuum tubes please | 65blkbkgt | Parts | 4 | 2nd January 2008 01:31 AM |
| Vacuum Tube Pre O.C.L. | gianmaria | Tubes / Valves | 13 | 16th February 2006 06:32 PM |
| World's Most Awesome Clock Radio | BAM | Chip Amps | 4 | 19th December 2003 09:10 PM |
| Good clock radio | eRiCdWoNg | Everything Else | 0 | 5th December 2003 08:21 PM |
| Page generated in 0.12290 seconds (82.08% PHP - 17.92% MySQL) with 10 queries |
