diyAudio Sponsor
Old 14th July 2011, 03:04 AM   #1
Doogie is offline Doogie  Canada
Default Graetz Scerzo Schematic
Hello,
I bought a stereo Greatz Scerzo model 6817-E console tube amp at an auction for $2.00. I can't find a schematic for it on the Web after seaching for a few days.
Output tubes are two El95's.
The power supply section is pretty messed up as there was an attempt to re-cap the power suppy capacitors I'm pretty sure the Selenium Bridge Rectifier should be replaced as I have heard they are toxic and prone to failure.
If any one has a schematic for this beauty and is willing to share it I'd be most delighted.
Yurs Doogie
Graetz Field Coil Shoog Full Range 12 14th July 2011 08:31 PM
Graetz Bridge Questions kacernator Power Supplies 2 20th April 2009 05:42 PM
Hybrid Graetz Bridge alexg Tubes / Valves 3 9th April 2008 03:45 PM
hybrid graetz in PSUDII JoshK Tubes / Valves 1 27th January 2007 01:50 AM
Page generated in 0.04726 seconds (76.08% PHP - 23.92% MySQL) with 10 queries
