diyAudio Sponsor
Old 13th July 2011, 06:52 AM   #1
Default Tube shops/supplies in Brisbane/Gold Coast
Will be visiting Australia for a week to Gold Coast / Brisbane area.
Any suggestions for shops/flea markets for tube stuff and supplies in the area worth a visit? NOS, used, etc... looking for mostly "budget" stuff.
Thank you.
Old 16th July 2011, 08:38 AM   #2
glennb is offline glennb  Australia
You won't find much of what you are looking for in Queensland. I have 2 retailers listed at Directory of Australian Valve Suppliers
Glenn.
Old 16th July 2011, 08:46 AM   #3
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Glenn, can you help him also to find some good but cheap oscilloscope?
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 16th July 2011, 11:39 AM   #4
I dare say that what is on offer in the US will be cheaper than what could be found in Australia, especially with the AUD being currently so high against the USD. There might be something on the Jaycar or Altronics web sites, the 2 biggest component electronics retail chain stores in Australia, see links below. Australia has 230V 50Hz mains, so check for 115V 60Hz compatibility. I believe Rigol makes a good cheap digital oscilloscope, not sure where you would get one from.
Jaycar Electronics - Search results
Altronics - Your One Stop Audio Visual & Electronics Supplier
Glenn.
Old 16th July 2011, 11:47 AM   #5
ratbagp is offline ratbagp  United States
A bit of a Google and I came up with
Valve Radio Repairers
and what looks more like what you want
Electronic Valve and Tube Company
Occasionally I go back to BNE to visit friends so could you let us know how these links turn out.
ray
Old 16th July 2011, 08:12 PM   #6
Thanks guys :-) Will definitely check out those links and let you guys know if I get lucky ;-)
@wavebourn : what scope would you suggest? am trying to source one from China but it will have to wait till my friend goes over for his business trip. What specifications should I look for?
Old 16th July 2011, 08:49 PM   #7
Wavebourn's Avatar
I guess, any scope is better than no scope at all.
I personally am absolutely satisfied by good old Hitachi V-555. Not the best, but good enough for my experiments.
Also, some functional generator is good to have. I have a couple of Wavetek 154, it is more than enough for me.
Old 16th July 2011, 09:56 PM   #8
the scope you quoted would cost in the region of USD500 over here at SECOND HAND PRICES :-(
Old 17th July 2011, 08:06 AM   #9
The Rigol DS1052E is a reasonabley cheap (< $400 USD if you shop around) entry level 50Mhz digital scope which has been mentioned on the sci.electronics newsgroup.
Glenn.
hello from gold coast aj-kun Introductions 4 9th December 2009 11:44 PM
Hello from Gold Coast Australia SVI3206A Introductions 6 20th October 2009 09:09 AM
Any Tube heads near Central coast NSW duderduderini Tubes / Valves 1 19th November 2007 02:16 PM
DIY Projector Setup (Gold Coast, Australia) Reason Swap Meet 1 28th January 2006 05:40 AM
Hi from Gold Coast, Australia Jack Whittaker Introductions 1 15th September 2004 08:24 AM
Page generated in 0.10755 seconds (70.94% PHP - 29.06% MySQL) with 10 queries
