diyAudio Sponsor
Old 12th July 2011, 05:30 PM   #1
Default 6Y6G tube for low-voltage SE amplifier?
I picked up a pair of nice coke bottle shaped Sylvania 6Y6G tubes.
Since their plate voltage is a maximum 200 volts.
Would it be possible to put together an SE amplifier using 120 line voltage and a pair of UF4007 diodes for SS rectification?
BTW: Cost is a factor in this particular amplifier build.
Since the 6Y6G tube requires 1.2 amps for heater current, I would use a 6.3v/4a filament transformer already in my possession.
Plus a 2.17A isolation transformer, again, already in my possession.
Would it be possible to use a 12au7 tube or a pair of 6au6 tubes as driver tubes?
A possible schematic would be really helpful (and greatly appreciated) also!
THANKS!!
Steve
Old 12th July 2011, 05:39 PM   #2
john65b is offline john65b  United States
john65b's Avatar
I would use an Isolation transformer, not mains (I may have misunderstood your post), and the 6Y6's I have tried do not sound as nice as the 6V6...
Will it work? Sure...will it sound great? Maybe. I was slightly disappointed.
"I speak Spanish to God, Italian to Women, French to Men, and German to my Horse" - Charles V
Old 12th July 2011, 06:25 PM   #3
No problem, but YES.....I have a big-n'-heavy 2.17A Stancor isolation transformer.
I figure I'll give the 6Y6G tubes a shot at least.
Especially if I can do this without spending too much cash?
Steve
Old 12th July 2011, 07:03 PM   #4
I was very happy with how this sounded.
Old 12th July 2011, 07:03 PM   #5
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
It is nice for SE in triode mode. In pentode better to use it for PP, to avoid quite significant 2'nd order distortions.
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 12th July 2011, 11:17 PM   #6
Do you have a set of triode curves for this tube? Data seems a bit hard to come by.
Old 13th July 2011, 12:03 PM   #7
http://www.scottbecker.net/tube/sheets/137/6/6Y6GA.pdf
Page 3 has the triode curves.
Old 13th July 2011, 02:56 PM   #8
Palustris's Avatar
Use it triode connected to drive a 300B.
SE Tube Preamp circuit using 6922/6dj8 at low voltage(24volt) needed! anyone? tone Tubes / Valves 7 20th February 2010 12:11 AM
Low Voltage Tube Preamplifier JammyBStard Tubes / Valves 173 19th February 2010 12:36 PM
845 Low voltage SE AMP =maximum= Tubes / Valves 8 19th July 2007 10:56 AM
Which tube for OPT 7,5k SE low watts??? Klimon Tubes / Valves 13 9th June 2005 03:26 AM
Low voltage Tube Schematic Elkaid Tubes / Valves 14 3rd February 2003 03:54 PM
Page generated in 0.10009 seconds (74.11% PHP - 25.89% MySQL) with 11 queries
